Question about GARDENA 30386 - 4 Hedge Trimmer
HAVE GOT TO REPLACE LEAD ON EHT 480 VARIO HEDGETRIMMER BUT CANNOT GET HANDLE APART HELP PLEASE
  • kentpauls Feb 16, 2009
    CANNOT GET HANDLE APART ORANGE SWITCH RING IS IN THE WAY ON MY GARDENA EHT 480 VERIO HEDGE TRIMMER SO CAN'T GET AT CONNECTOR TO REPLACE LEAD
    A RIGHT BLOODY RIP OFF
    MANY THANK
    PAUL
    Genius:
  • 1,075 Answers
First make sure mains lead is disconnected and no power is connected then remove all screws visable and please remember these tools are all pressed shut for extra safety so a little persuasion will be needed ,once your happy everything is ready to go ,gently put a blunt intstrument in between the two matching sides move along gently until the two sides start to part; as you move along you will notice them coming apart please take your time.when you put the blunt intstrument inbetween the two matching sides do not put it to deep as this could cause internal damage.also watch out for small locking clips inside the casing as these can break quite easily ,sometimes a small screwdriver is all that is needed to push these clips open.after a period you will find the casing starting to part quite openly to reveal the connection strip you need to get at.;;from experience i would start where the wire comes in to the casing; its the weakest part of the casing.i hope this will help you.adrian
Posted on Feb 16, 2009
  • adrian halligan Feb 16, 2009
    all external casing parts ie;non slip handles and other parts can be removed by inserting a small screwdriver gently under them and forcing them gently to pop off [if not screwed].
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would appear that the orange ring serves 2 purposes:
  • lock the handle together;
  • act as cover for the switch.
Other than the screws, the orange ring must also be removed:
  • If it is soft and pliant, then it would have to be forced out of the locking grooves by inserting a flat bladed screw drivers to snap it off position and thereafter slide out of the handle;
  • If it is hard and seem to break easily, then it has to be heated to soften it and therefore make it easier to stretch. A hairdryer on low setting should do the job.
In some instances, WD40 oil would also help make it jump out of the locking grooves.
Good luck and thank you for using FixYa.
  • 19,396 Answers
Here you can get the schematics for a Bosh Edgetrimmer, that is similar.
If that helped remember to rate the solution.
Thanks.
  • 126 Answers
No , you cannot get handle apart. Either you buy a new one or if you want to use this one only than you can use something which can be fit in its handle.
pls rate me
thankyou
  • 286 Answers
Hi
The handle should be in two parts, held together by the screws along the handle.
Once you have extracted them , the handle opens up, bit like an easter egg, and you will see the trigger switch, to which your main feed cable is connected.
Simply undo the terminals, and fit new cable as was the original, noting color code, and reassemble handle, and secure the screws, and test the unit before use.
Good Luck !
Any problems, give me feed back !
A FixYa rating would be nice ! Thanks John.
    Brigadier General:
  • 3,614 Answers
do you have a user manual with you?
  • micromaster
    micromaster Feb 16, 2009
    Levers are
    typically located on the rear handle and keep the blades from moving while
    the engine is idling.
    * Stop buttons. Stop buttons are basically a kill switch. Most
    commercial-trimmer manufacturers don't offer this feature because of the
    additional cost it adds to the units.
  • micromaster
Lead short
The handles are made to come apart- jsut take out the screws on the side of the handle. It will sometimes need some help from a screwdriver to pry a little, but it should come apart.
Mar 25, 2012 | Welding Tools
Hello I have monitor samsung Smatron 7Ei the fault is that the picture is very dull with less contrast and bright. CRT heater volgate is ok. Secondly there is a heavy noice when i start it by power...
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - TV TUBE ) becomes weak - then 1 of the indication is ....picture becomes dull (less brightness & less contrast --- that noise is from EHT )........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.....
Apr 18, 2011 | SAMTRON 55V 15" CRT Monitor
Power on but no display
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....monitor LED just blinks & no display .......so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( very much compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching monitor --- this adjustment is very important ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around Rs 250 ( US $ 6 ) & for my customers (in bangalore) i will take another Rs 500 (US $ 11) as service charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact monitor service engineer ------- because they are highly experienced & can fix this component very easily.... SOME TIMES ALONG WITH EHT....A TRANSISTOR ( BIG IN SIZE & FIXED NEAR EHT) ALSO GETS DEFFECTIVE...........SO IT SHOULD BE COMPULSORYLY CHECKED BEFORE REPLACING EHT
Feb 07, 2011 | Samsung 793S 17" CRT Monitor
Over briteness and top botam both side cuting
open the monitor check eht rotate the preset on eht named screen brightness will be controlled
there is a three lead diode attached to heatsink near eht replace it even found ok problem of oversized display will be solved
Feb 07, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Ibm e74 17 crt monitor screen is black with the indicator light flashing green.
Jan 24, 2011 | IBM E74 17" CRT Monitor
Disply very slow please help me
after 4 or 5 yrs EHT ( transformer that supplies voltage to CRT TUBE - MONITOR TUBE ) becomes weak - then 1 of the indication is ....it takes few mins for picture to appear...........so solution is EHT ( also called as flyback transformer ) should be replaced....... {{ few details about EHT---- its size will be around 3inch X 2inch X 2inch ---it will have 2 or 3 knobs to adjust focus , brightness ------ at bottom around 10 pins will be there ------- from EHT 1 thick red colour cable goes to CRT TUBE --------- on EHT its part number will be there }} -------- so if user is a technical person having idea about components ( resistors, transistors, diodes, etc ) , having tools like multimeter ( to check components) , soldering iron, soldering lead, flux, desoldering wig ( for removing components), etc also little experience in servicing field( compulsory) ----------------- then user can remove EHT from main board ---- take to electronic shop ----- buy same type EHT --------- fix to mainboard ( knobs on EHT should be adjusted according to picture --- after switching MONITOR ) ----------iam from bangalore (09986222774, sathyavijayasarathibabu@ymail.com) ----- here EHT's price will be around US $ 10 & for my customers (in bangalore) i will take another US $ 12 as sevice charge......i don't have any idea about EHT ' s price & service charge in your place.........since it is very risky job i suggest to contact MONITOR service engineer ------- because they are highly experienced & can fix this component very easily.....
Jan 17, 2011 | LG Flatron 775FT 17" CRT Monitor
I have a Bosch AHS 42-16 Electric Hedgetrimmer . I don't like its 'hard wired cable' and I wish disconnect this and insert a safety 'easy disconnect' plug. My problem is knowing what type of 'star key' I...
Go to your local home center, or a hardware/tool store, or even Harbor Freight. For less that $10 you can buy a kit that has a screwdriver handle and the 'forbidden' bits for screws that manufacturers use to keep you from working on your own equipment. Some are called "Torx" but there are others too. If you can take the equipment with you, you can be certain to get what you need. Now that I've shared this secret, please don't electrocute yourself -- unplug before your unscrew! Good luck.
Aug 16, 2010 | Garden
Eht lead of my tv is spiking (arcing) to the tube
Hi, which end of the lead, is it the eht transformer or the anode end that plugs into the tube. I may have a hole in the lead somewhere and the voltage is arcing to the tube.
Check this and if it is the case then you will need to buy a new lead.. or try a load of installation tape.
BUT PLEASE BE CAREFULL, THERE IS EXTREMLY HIGH VOLTAGES IN THERE IN THE KV RANGE.
SO UNLESS YOU KNOW WHAT YOU ARE DOING , TAKE IT TO A SHOP.
I WILL NOT BE HELD RESPONSIBLE, IF YOU KILL YOURSELF.
If I have help then please rate me.
GOOD LUCK.
Regards - Anthony
Feb 09, 2010 | Televison & Video
Brightness Problem
Since focus adjustment using the flyback rear controls (EHT) has no effect, then it could possible mean two things:
  • the EHT is defective (most likely) at least the controls; or
  • the picture tube is already weak.
A workaround is to replace the filter capacitor of the ~70V leading to the collector voltage of the 3 color drive transistor. Normally used to replace with is 100uF/160V.
Of course best would be to have the EHT checked/replaced.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Sony comcorder
I Need Imidiatly Sony Handycam CCD-TRV25 480 8mm Analog Camcorder where from i can perches iam in Dubai please tell me now i will be thank full to you +971558542021 aslamj2000@yahoo.com
Oct 03, 2007 | Video Cameras
GARDENA 30386 - 4 Hedge Trimmer Logo
117 people viewed this question
Top GARDENA Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a GARDENA Garden Expert? Answer questions, earn points and help others
