Question about Samsung SP50L7H 50" HDTV-Ready Television
Samsung sp50l7hx will not come on
When turning on tv it cycles as normal but the ''smiley face'' does not come on, so it tries again, does this about three times. Then the warning triangle appears with the lamp symbol, the manual says this could mean the lamp needs replacing or ''another component.''
It is the fact that it could also be an other component that is worrying me. The bulb was replaced a year ago, the original bulb had lasted three years! Have taken the bulb out and there is no obvious signs that it has gone, the original bulb went with a load bang and broke into pieces!
Any help would be appreciated.
2 Suggested Answers
hardrocko
  • 1476 Answers
SOURCE: I have a HL-P5085 that illustrates the triangle
slusher17,
You most likely have a bad lamp ballast or possibly a bad power supply. When the lamps fail they can draw quite a bit of current and damage the ballast. High pitched sound indicates a short somewhere, more than likely the ballast, which puts too large a draw on the power supply, which is a switch mode unit, causing it to slow down the oscillations to a level which you can hear. I would recommend a new ballast. You can get it for $70 US at http://www.encompass.com and the part number is BP47-00027A. I have a tip at http://www.fixya.com/support/r4977572-when_change_ballast_in_dlp_tv which will walk you through the installation process.
Thanks for using FixYa and consider a great rating. Ratings and testimonials are important to keep experts working for you. Thank you.
hardrocko
Posted on Oct 29, 2010
Testimonial: "I really appreciate your opinion and it's reassuring to know there really is someone 'out-there' that will take the time to help. Thanks for the links"
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
I don't receive smiley face in text only blank text? straight talk
This is normal, you can change this setting in some browsers.
Once sent or uploaded other people will get the full smiley face if there browser allows it.
Feb 14, 2014 | Computers & Internet
Problems with my Samsung TV
The wires are not connected to the tv stuid
Jan 29, 2014 | Televison & Video
How do i add a smiley to my text
how can i set smiley faces and... on my phone?? on(galaxy ace)
Feb 12, 2012 | Samsung Galaxy S GTI9000 Smartphone
I'm trying to figure out what this means in a text I received :-). Also :-P
That are smileys,its like expressions. your mobile set does't support it. so you are getting it like that. (it will be like a head symbol)
May 10, 2011 | Cell Phones
I have samsung GT_s3650,there are no smileys in it bit have graphical symbols. I want smileys while doing messages.How will i activate the smileys for my txt.
This is one of the annoying aspects of this phone... The smileys show as symbols & not like the yellow faces like nokia phones etc. Unfortunately there is no way to activate smileys
Apr 17, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
How do i add smiley faces to text on galaxy s?
To add smiley in your text messages, you will have to select option when you are typing a message, then you select smiley from the option, then it will give you a list of available smileys, from there you can select the one of your choice and add to the message you are typing.
Jan 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
My samsung dlp tv sp50l7hx had to bemoved to lay
although the lamp may look ok your tv has all the signs of lamp fail they only need a slight bang. I know that it is cheaper to replace lamp than light engine
Nov 08, 2009 | Samsung SP50L6HX 50" DLP HDTV
Smileys for my samsung E250 mobile
Your device is only defaulted to use certain emoticons, symbols, and numbers. There is no software available that will allow you to use animated emoticons. Learn to use the symbols you have to create the smiley face you desire.
If your phone will support certain IM's, that is the only other way possible to use animated emoticons through IM. Thanks.
Mar 19, 2009 | O2 Samsung SGH-E250 Cellular Phone
DLP SP50L7HX
tvlamp is starting to bail out
May 24, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung SP50L7H 50" HDTV-Ready Television Logo
245 people viewed this question
Henry  Thomas
Henry Thomas
