Question about BUSlink Electronics - Others
Cant remove write protect
It says that my EMTEC usb is write protected. so i cant add or remove files from it. how can i fix it?
    Scholar:
  • 77 Answers
Download this small file:
http://www.kellys-korner-xp.com/regs_edits/writeenable.reg
Save the file on your desktop. Then double click the writeenable.reg file and click on Yes when Windows asks if yo u want to write to registry.
That;s it. Now you can try to create a new folder on your usb drive and it should be created. That means it's now normal.
HTH,
Regards,
Deboo
Posted on Feb 17, 2009
  • Deboo Geek Feb 17, 2009
    You will need to remove the USB and re-plug it or may be a reboot is needed before it will work normally.
How to remove write protect on my usb flash drive
Check device for a small switch, sometimes it's hard to see.
Jun 20, 2012 | Electronics - Others
Tip
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button disablewriteprotection_thumb.png
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
on Jun 19, 2010 | Computers & Internet
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
Vibratim 4GB flash ram write protected not writable and i cant format it
Oct 15, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
My memory stick is write protected...i cant add/delete files.
CHECK if it is not physically protected, a small button/switch might be on the stick!
THEN, try any other flash drive or memmory stick to locate the target problem (memorry stick, or usb port mulfunction or even security/driver issue).
PLUS, there are some programes that might protect flash drives, check if u have any, and uninstall them, and make sure u have deleted ther HIDDEN system files located on the stick!
gd luck.
Jan 01, 2010 | Electronics - Others
Remove Write Protection
click on it by right click and then format, if this cant be done then read the user manual that comes with a werbtin i am using the same type
Sep 04, 2009 | Electronics - Others
My 1gb kingston pen drive is write protected
Try to right click your pen drive then copy and paste it on your My Documents folder. When done, follow these steps:
1. Go to start menu
2. Click Run and type cmd
==A command prompt shows.==
3. Type cd\
4. Type format x:
5. Press Enter key
6. When done type exit
Note: Copy all the files you have transferred on your My Documents folder and paste files again to your pen drive. You can now do whatever you want on your pen drive.
Dec 25, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
your mp3 is damaged im afraid, no other way around it
sorry
Nov 02, 2008 | Samsung YP-U3 MP3 Player
There is a software on internet, it is FREE of charge, it is called unlocker, it's a simple installation that lets you delete, rename, move any file/folder, just right-click the desired file/folder, go to"Unlocker" the image is a wand, and select the option you want.. works for me. good luck. hope this helps
Jun 02, 2008 | Creative Labs Zen Digital Media Player
Electronics - Others Logo
542 people viewed this question
Top BUSlink Electronics - Others Experts
Are you a BUSlink Electronics - Other Expert? Answer questions, earn points and help others
