Question about HP Officejet Pro K850 InkJet Printer
Printer Not Responding
The printer is on and plugged in, but my computer says that "communication with printer" with not there. Everything is plugged in and turned on, and my firewall setting is set correctly.
    Sergeant:
  • 183 Answers
Turn your botho (PC and printer) of an turn it on that may solve this problem.
if after doing this also still remain the bug the reinstall your printer driver in PC.
Good luck and rate all the asnwers.
Posted on Feb 16, 2009
Why am I getting a "Server Failed" notification when running the network diagnostics?
The printer is not communicating with the computer. Recheck the IP address on the printer against which port on the computer is selected. If everything checks out ok then uninstall the printer driver and reinstall.
Oct 28, 2014 | Ricoh Aficio CL7200 Laser Printer
How do I get my printer to communicate with my computer
If you have the software then this is easy. For the setup, plug your printer into your computer and run the software. It will find the printer and prompt you to set it up wirelessly. Go through and answer all of the prompts and it will be complete. At that point you can disconnect the cable and run it wirelessly on your network or Bluetooth.
Aug 25, 2014 | Lexmark Pro 205 Multifunction Printer -...
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
Printer not responding to print message order
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Sep 12, 2011 | Lexmark X2600 InkJet Printer
I get a message saying the printer cannot communicate with computer. Everything is connected properly. Also, the wifi light is flashing. Sometimes it prints, but it randomly cannot...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Unplug and re-plug the printer into the power source to reset it. Reboot your computer.
You may also refer to this article found in the Lexmark website: How to identify a Wireless Communication Problem and Resolution Tips.
Jul 13, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
My lexmark x6650 printer will not connect back online
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via USB cable to your computer, simply disconnect the printer from your computer, reboot your pc and unplug/re-plug the printer into the power source to reset it. When everything turns back on, reconnect the printer into the pc. Wait for the computer to fully recognize the USB connection. Try to print again.
If you're printer is wirelessly connected to your computer through your wireless network, please refer to this article for a more comprehensive instructions on how to identify and fix the communication problem - Wireless & Network Communication Issues with 2008 Lexmark Inkjet Products
Jul 06, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
uninstall and reinstall software,takeout plug of printer for 2 min. and let it reset.I have the mfc-240c experienced the same problem ,did this and now it works fine.
Apr 28, 2009 | Computers & Internet
Communication problem printer lexmark2600
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Jan 12, 2009 | Lexmark X4530 InkJet Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Cannot communicate with printer...
my printer is not doing anything. It pops up " cannot communicate with printer." please tell me what I can do. I have tried everything I know.
May 09, 2008 | Compaq Inkjet IJ650 Printer
HP Officejet Pro K850 InkJet Printer Logo
56 people viewed this question
Ben Johnson
