Question about Asrock P4I45G Motherboard
HOW TO GRAPHIC CARD
I GOT Asrock P4I45G Motherboard I WANT GRAPHIC CARD COMPATIBLE WITH THIS MOTHER BOARD TO GIVE OPTIMAL PERFORMANCE
  • raoright Feb 16, 2009
    I GOT PCI SLOT
  • Maximum Memory Capacity: 2048MB
  • Currently Installed Memory: 512MB
  • Available Memory Slots: 1
  • Number of Banks: 2
  • Dual Channel Support: No
  • CPU Manufacturer: GenuineIntel
  • CPU Family: Intel(R) Pentium(R) 4 CPU 2.40GHz Model 3, Stepping 4
  • CPU Speed: 2393 MHz NOW U TELL ME
  • paspap Sep 16, 2009
    I had the same problem.. Buy an hd3450 (ATI) 512mb.. and the system dont recognize it :(
    • 530 Answers
    Hi im josh in cebu phils. may i helped you? It simple problem friend. since your motherboard is p4 and it has an avp slot not pci e.You buy AGP graphic card having a higher memory 256 or 512 mb and 128 or 256 bit. so that you will get the the best performance on that p4 board. i suggest to get higher ram and bigger hard disk space and a sound card for maximum performance.Good luck..
    Posted on Feb 16, 2009
    Motherboard starts but no signal in the monitor
    Hello here is the cpu list:
    http://www.asrock.com/mb/Intel/P4i45G/?cat=CPU
    Other cpu`s than them on the list, does not fit the mainboard.
    This will cause the mainboard not to boot up, when the cpu is wrong.
    The (wrong) cpu will fit the socket, but it does not fit the cache size, fsb, and so on.
    Look also in the manual:
    http://www.asrock.com/mb/Intel/P4i45G/?cat=Manual
    The problem could also be the power supply failing, try to change that.
    Did it boot up before you changed the cpu ???
    Any beep codes ??
    Look also at this page:
    http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
    Good luck
    Feb 17, 2013 | Asrock P4I45G Motherboard
    Hi Guys, I have Asrock 775VM8 mother board, and want to upgrade the graphic card to ATI 9600 Pro (256 MB). I just wonder if this motherboard can support that card at all. The motherboard clearly says...
    Since your motherboard is responsible for the supplying power to your card there is no harm in mounting the video card. As far as i know if the voltage capacity of the video card is lesser than the voltage supply of your board then you should not try it. AGP gets its supply from motherboard so do with PCI slot. You will notice the performance of the video if the supplied power from your board is not sufficient.:D
    Mar 15, 2011 | Asrock 775VM800 Motherboard
    Want to know that "ASRock G31M-S" is compatable with Nvidia 9500
    Your new card maybe faulty or you might need a larger Power Supply Unit (PSU),, if its just started to happen...
    Jul 30, 2010 | Asrock G31M-S Motherboard
    ASRock Wolfdale1333-D667 and Radeon 5770 graphic card
    Actually, one thing. Intel motherboards, like your Wolfdale is an Intel board, they don't work with AMD graphics cards. I've seen this arise many times, the graphics card is AMD and your MOBO/CPU is Intel... that's a red flag in my book automatically. Take it back and try an Intel Graphics card.
    Oct 20, 2009 | Asrock P4I45GV R5 Motherboard
    Give computer graphic for make ivcons small
    open link and download driver.....
    http://www.asrock.com/mb/download.asp?Model=P4i45G
    Jul 01, 2009 | Asrock P4I45G Motherboard
    Which latest Graphic card can be supported by my Asrock P4i45GV?
    Hi
    Any video card that supports AGP x8 Should work on this motherboard.
    For example Nvidia 7800 GS AGP or 7600 GS AGP should work fine.
    But a better investment would be to upgrade the motherboard to a PCI-E supporting board and possibly AMD Dual or Triple / quad core processor the ram is very cheap for DDR2 these days.
    Upgrade would be best in long run.
    Feb 02, 2009 | Asrock P4I45GV R5 Motherboard
    Mother board - video card compatibility
    if you have a built in video on mother board there is a setting in its setup hit delete at beggining right at startup for bios
    you need to disable your built in video either by jumpers by manufactures book on jumper settings or go into bios at begining and see if there a setting to shut off on board video
    these 2 are having conflicts with each other and you will only be able to see dos boot area with both these cards
    and yes it is compatible as long the buses and slots have same configurations
    May 07, 2008 | Sapphire RADEON™ HD 2600 Pro, Graphic Card
    BIOS battery
    I supose you have set the correct date in bios?
    Apr 04, 2008 | Asrock P4I45G Motherboard
    ASRock K7S41 no boot screen at all
    Try plugging the monitor to the onboard video card and then enable the graphic card in cmos settings.
    Dec 10, 2006 | Asrock K7S41 Motherboard
    Asrock P4I45G Motherboard Logo
    111 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    Iqbal Husain
    Iqbal Husain
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
