Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Water coming out of the powder draw when the draw is closed
Hi, i have a secondhand hotpoint wd62, i have cleaned all the draw and inside and placed the draw back in with powder, but when the water comes into the draw to take the powder water runs out of the draw front and down the machine front, i have tried lifting the front so that the angle is slightly backward but this still happens, can anybody help?
  • johnstone_de Feb 16, 2009
    Thank you for that , i will try that when i get home tonight. cheers jim.
  • 134 Answers
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Posted on Feb 16, 2009
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
I got an hotpoint wma64 front loading washing machine and my water intake has stopped working i am filling the machine with a hosepipe what can i do to fix the problem?
water goes through softner and powder draw hole gets gunged up stopping water supply take drawer out and clean then clean inside where draw fits black gunge blocks small hole where water comes through should do the trick
May 15, 2010 | Hotpoint WMA64 Front Load Washer
How do you clean the water entry point into the
Remove hoses from valve at the back of washer, remove screens inside inlet valve use a small screwdriver to remove, clean screens and REINSTALL SCREENS IN VALVE, INSTALL HOSES
Dec 22, 2009 | Washing Machines
Water is coming out of powder draw everywhere and washing machine is not emptying propley
You need to clean the filter.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Dec 21, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint wd62
Try taking the top off, power off obviously!! and remove the draw unit, there is a pipe that runs from there to the drum.... I found a sock in mine that was the problem !!
Feb 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WD62
try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Jan 13, 2008 | Hotpoint WD62 Front Load Washer / Dryer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Why dont my machine take the soap powder
Assuming that the bit the water is going into is the prewash dispenser (rather than a bleach or conditioner dispenser), why not just put the powder into there? Some of these machines can be a bit illogical about where the main wash powder is meant to go - sometimes even varies depending on which cycle you're running. If you can find a place that will take the powder at the right time, your problem is solved. If the instructions say different, it might even be them that's wrong. Wouldn't be the first time. A.
Mar 04, 2007 | Hotpoint WM56 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
245 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
