Question about Dell Computers & Internet
Install older version of windows xp professional
Gave in my computer for repairs and they installed their copy which is a newer version. I now want to install my own copy whic is an older version. Also the microsoft site is asking me to activate my windows
  • 40 Answers
Hello.
First do this.....
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
1. Put your old XP CD in and reboot.
2. After reboot if asked if you want to start on cd chose yes.
3. start Win Xp installation from your old XP cd.
4. delete partiton 1 on your C: hard drive
5. create new partition
6. Start installation and format the c:drive
7. Follow the installation instructions,,,
Hope this helps.
Regards...
/Tech5508
Posted on Feb 16, 2009
Problem with the installation of Windows xp professional
Windows XP is no longer supported by Microsoft. You have to install a newer version.
Aug 15, 2017 | Microsoft Windows XP Professional for PC
Tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 | Computers & Internet
It says it cant start or run do to incompatibility with 64 bit versions of windows....any way i can make my mission think game work? :/
The Learning Company Super Solver Mission T.H.I.N.K. was released in 1999 for Windows 3 and probably Windows 95/98. It could run under XP in the compatibility mode.
For a newer Windows OS, you need a workaround. You can use a a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer using the compatibility mode and it should work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. If your computer has a USB keyboard and mouse, you will need to use Win98 or newer OS. (However, the drivers may be an issue with Win98.)
For the compatibility mode, right click on the installer and choose Properties. In the compatibility tab, check the box for Run as compatible with an older version of Windows. Then launch the program.
I hope this helps.
(Windows 95b supported USB but it wasn't really ready for the USB)
May 14, 2011 | The Learning Company Super Solver Mission...
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
My ksuser dll for windows xp profesional
Just boot from the xp professional cd and run the recovery console.
or
Apr 19, 2011 | Microsoft Windows XP Professional
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
or
Apr 18, 2011 | Computers & Internet
Acer aspire 5600. Did a system restore and the computer would not start the windows programme then stopped trying and comes up with 'ntldr is missing' and won't get past that. Any advice would be much...
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP. There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade.
1-Boot with the Windows XP CD and at the Setup Screen press the Enter Key
2-You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed
3-
The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
When Setup has completed you should find all of your previously installed apps and settings are intact.
Feb 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
The wmplayer plays but no video appears
There is a more recent version of Windows Media Player (11.0.6000.6344)
already installed on your computer. It is not possible to use an older
installation package (11.0.5721.5146)
to install the files or to repair your current version of the Player
Feb 03, 2010 | Microsoft Windows XP Professional for PC
Computer froze
Yes, it does. Try this:
How to Repair Install: ***Also removes Service Packs***
There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade. Create a Slipstream version to solve this problem
If you cannot boot to the Desktop, or you have an OEM version of XP, or you want to remove a service pack then the following should be used to complete a Repair Install.
You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed.
setup02.jpg The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
setup03.jpg Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
setup05.jpg rc%20017.jpg setup06.jpg When Setup has completed you should find all of your previously installed apps and settings are intact.
Jul 17, 2008 | Dell Inspiron 8600 Notebook
Windows error
Hi notsoscrewed- As long as you have your original XP disk you can save everything. First, make sure your pc is bootable from your cd drive. If you know it is good. If not, when your pc boots it should say something like hit F2 or <del> to enter setup. Go into the BIOS and find your boot options and make sure your cd is listed as bootable and listed to boot before your hard drive. Then save and exit. When your system reboots make sure you have your XP cd in your cd drive and your pc will say press any key to boot from cd rom. Press any key and follow these steps:
You must boot from your XP CD. Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
Before the Windows logo appears, you will be asked to press any key to boot from CD, so do just that.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts, have your CD-KEY handy . You may have to install XP updates again and reactivate XP but small price to pay and little time to be able to save all your software and info. Let me know what happens.
If this solves your problem PLEASE rate this as fixed. If you need more help with this just add a comment and I'll be more than happy to assist you further. Thanks.
Jeff
Jun 23, 2008 | Computers & Internet
Computers & Internet Logo
141 people viewed this question
Alun Cox
