Question about Nokia N95 Cellular Phone
Nothing works i was talking on the fone but i dropped it and the fone was fine for about 20 secconds then it crashed and now it wond do anything can any one help?
  • 544 Answers
the main reason why is your mobile already not working because the LCD are maybe dislocated or some parts of your mobile are damage if you have tools to open it you can try to check the LCD if it is still in his natural position or not damage but if you don't have any tools to use i prefer to advice you that go to the nearest cellphone repair shop so that they can fix it and open carefully.
Posted on Feb 16, 2009
97 nissan 200sx se 1.6l problem. I got my engine replaced with a 99 it was doing this before I swaped out engines so here we go start my car up and revs like should when u start it up idels a lil high for...
I doubt it is anything other than the iac valve or the computer.
You could unplug the iac and see what it does, the throttle cable could be hanging up in the car too.
Aug 30, 2012 | Cars & Trucks
Ihave a k8501. was using it one day when it crashed and now i cant get it to do anything. when i try to switch it on it vibrates and the keys light up but nothing else. what can i do?
its the BROD (blue ring of death) bug in the firmware. i had it couple of times but manage to make the fone work again.
solution
you simply have to reinstall the firmware via SE update service.it take some time so have patience and eventually your fone will start again.
Jun 10, 2009 | Sony Ericsson K850i Mobile Phone
I dropped my sidekick 2008 in the toilet
really the only thing to do in this case is to let it dry COMPLETELY before putting any power to it. if you let it dry completely now it may still work but if you tried it already and it failed i doubt it. try a new battery if it wont turn on. i dropped my nokia in the toilet and let it dry for 3 days then it worked; had a buddy spill his bottle of beer on my blackberry and after the defrost and over night it worked fine.... good luck
Apr 26, 2009 | T-Mobile Sidekick "Gekko" cellular phone
My LG Dare was fine one seccond and the next its broken
i need the personal license key for mp3 palye from nokia3230
Feb 13, 2009 | LG Dare VX9700 Cell Phone
Camera not working
o as long as you didnt drop it hard or anything like thet or drop it in water you should go to the store that you got it from and they will check it out then send you a new fone and you will give them your fone to check and make sure you didnt do anything to it and you will keep your new fone and your old one will b kept by them to try to fix hope i helped!
Jan 01, 2009 | LG RUMOR Cellular Phone
Black Screen with horizontal lines
are u sure that ur not able to see the fone's stand by screen now?its totally black?are u sure that there's no problem with the screen itself,the care guys might have left the screen connection loose. other wise try one thing,Format ur fone. by pressing *#7370# u have press keys once wait for 5 seconds and press the left selectin key [where u get the YES option normally. the fone would restart and lets see are u able to go back on the screen. IF YES then u can set the Sleep mode to off cuz the sleep mode gets inititated after 20 minutes when u keep ur fone idle means u dont operate ur fone for atleast 20 minutes. BUT IN THIS CASE ULL LOSE ALL UR DATA INCLUDING CONTACTS AND MESSAGES ETC.IF U HAVENT TAKEN THE BACK UP EARLIER.so its totally upto u that u want to proceed with this step or u can again show ur fone to the nokia care guys. but they'll charge u cuz obviously after 2 years ur fone is out of warranty
Oct 05, 2008 | Nokia N73 Cellular Phone
My blackberry has crashed
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Sep 10, 2008 | RIM BlackBerry Curve 8310 Smartphone
Screen problems
you have to remove the back of the phone with a small tri screw driver. underneath the board in a corner there is a flat cable that connects the screens to the board. It came loose. press the flat cabe back into the the board chip. they will lock together. the screens will work.. I just did this with my sons phone.
Jan 03, 2008 | Kyocera Switchback KX21 Cellular Phone
Camera says busy, try again later
did you recently dropped your fone? if yes, open up your fone on the display part and try to push back the camera connector module. hope it works. if not theres a problem with the flex cable of your fone
Nov 26, 2007 | Motorola Mobility V265
Motorola L6 earphone problem
dear i think your habdset dropped once and its speaker fone connection is loose
Oct 22, 2007 | Motorola Mobility L6 Cellular Phone
Nokia N95 Cellular Phone Logo
24 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
