Question about Acer Aspire 9300 Notebook
Cursor locks up on my acer extensa 5620
My cursor locks up on my acer extensa 5620 when i dont use sometimes for 5 minutes or less. i'm sick of tired of turning it off at the power button and turning it back on, does anyone why this is happening? any help would be greatly appreciated, with thanks.
  • annridding1 Feb 16, 2009
    done this, will restart my laptop and hopefully it will resolve the issue, thought it might have been a vista issue lol. i have it on power saver but it always plugged in at a powerpoint.
  • 326 Answers
You need to go to your control panel then power options, on the power schemes turn the 3 setting you have to never.
let me know how you get on
Posted on Feb 16, 2009
  • mark hudson Feb 16, 2009
    even when you have it plugged in it will still go on standby with the power saver wehn you havent used it for the set time, can be annoying
    did this solve your problem, if yes would you mind rating this please
    thanks
My acer laptop extensa 5620 will not turn on,it is totally dead with no lights showing and no sound coming from the laptop, i have taken the battery out and plugged in the power cord and still nothing
My Laptop wont turn on [Solved] - CCM
ccm.net > Forum > Hardware > Laptop
Nov 13, 2015 - Hello,i need help.my acer extensa 5630ez wont turn on.i tried charging it for hours.it still wont turn on.when its plugged in, the battery led light ... My acer laptop wont start up!!! [Solved] - CCM
Jan 10, 2015
Connecting an external monitor to my Acer [Solved] - CCM
May 3, 2013
Mass storge controller acer extensa 5620 [Solved] - CCM.net
Apr 27, 2011
More results from ccm.net
Acer extensa won't boot. FIXED !! - YouTube
? 0:28
https://www.youtube.com/watch?v=Tb8hzSqWnjs
Apr 1, 2011 - Uploaded by Gen
Watch the fix i used here http://adf.ly/Pnk8u Acer extensa 5420won't boot. ... MADE THE LAPTOP HOT AND TURNED IT ON AND IT WORKED!
Acer Laptop Stops Powering Up- Wont Turn ON - Tech Support Forums ...
www.techimo.com > Forum > PC Hardware and Tech > Technical Support
Jun 5, 2010 - 11 posts - ‎3 authors
Dec 21, 2015 | Acer Extensa 5620 Notebook PC
How do you recover an acer extensa 5620 that lost its recovery partition with out a back up disk?
press power button & same press alt+f10 now recovery mode is come & show retain used data now select & refresh select now chek .
Sep 01, 2017 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 no signal and the power on and off three times and go off
Hi
I understand from your short ( very short ) words that the laptop won't start.., if so :
Please remove the battery, hold on power button for about 50-60 seconds, then plug-in the charger and turn the laptop ON,
Please tell us your results
Good Luck
May 14, 2011 | Acer Extensa 5620-4677 Notebook
Passwor bios phoenix trustedcore de acer extensa 5620
pull out the cmos battery as well as the battery, and leave it for 3 minutes. then put the reg. battery back in and boot it up. it should say password disabled. Turn it off and put the cmos battery back in, it should work now. leave positive feedback!
Jan 13, 2011 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 laptop will not boot uo
Then you can check 2 things to see if the machine will boot. If not, then you'll need to get it repaired. FYI, I repair Acers.
Step 1 - remove the battery and the A/C adapter from the back of the computer for about 2 minutes. Replace the battery and the adapter and try to start the machine. If that doesn't work, go to step 2.
Step 2 - Check that the A/C adapter is getting power and the LED for battery charging on the front of the computer lights. You can check the voltage from the power supply with a volt meter, if you have one -- it should read around 18-19 volts. If either of these steps don't work, you'll need to get it looked at.
Problems could be with the power supply, motherboard, power switch, CPU or something else that only time and expertise could properly track down.
Jan 08, 2010 | Acer Extensa 5620-4020 Notebook
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
Aug 25, 2009 | Acer Extensa 5620-4020 Notebook PC
Acer extensa 5620
i have laptop acer extensa 5620z, install windows xp professional os 32 bit, inside device manager open that time
Ethernet controller
Ethernet controller
Mass storage controller
Pci device
Pci device
SM Bus controller
Universal serial Bus (USB) controller
biling the yellow(!) mark, and usb device put in the usb port not open how to solve this problem, please reply me, thankyou,
my email senthil_japan@yahoo.com
Jan 26, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 5620 it shutdown but stiil power remains on.
please install "Avast antivirus" after installing the antivirus, system want to restart then you must restart your sytem , then the system scan all drives for viruses at boot time,if any virus is found the system will want to delete it by pressing 2 and it will delete all viruses from your system, then you must repair your operating system with xp bootable CD , after repair you must install your system drivers......... and then your problem become solve
Jan 25, 2009 | Acer Extensa 4620 Notebook
My acer extensa 5620 blutooth dont work when i press butom write no devise found i intall driver but still dont work
check in device manager that is it working properly. try reinstalling the drivers again, download from here:
http://support.acer-euro.com/drivers/notebook/ex_5620.html
Dec 25, 2008 | Acer Extensa 5620-6119 Notebook
Acer Aspire 9300 Notebook Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
