Question about Whirlpool GHW9100L Front Load Washer
Suds Message and washer stops cycle with with F02 code and beeps
I have a whirl pool washer GHW 9100 LW2. Had it for 4 yrs. My problem: First I get a SUDS message. Then the washer seems as if its if its going thru a extra cycle to fix the problem as manuel mentioned. During this period there is a unuseal noise coming from a black type unit thats connected to the water drain plug that you can screw out to drain the water from the tub. Its is on the right side of the screw drain plug which is behind the panel underneath the washer door. Then the cycle stops. Water remains in the tube. Then a F02 code pops up and the machine constanly beeps. I have drained the water a few times but never saw any blockage. Just very small strands of debree form clothes.
Please Help. Thanks !! God Bless !!
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if you may have a problem wiht oyour drain pump"the little black thing onthe side of the drain screw" something might have gotten into it and damaged it causing the noise and now not pumping out effiently. as far aas "suds" this could berelated to your problem , for if soapy water not being drained youlll getthis condition, but i would check your detergent . You NEED to use an HE detergent(HE high efficency spefically designed for front l;oading machines)
Posted on Feb 16, 2009
My Kenmore HE 3 washer keeps stopping mid cycle and beeping showing an F 02 message. We cleaned out the hose but it is still doing it. If I unplug it and do the spin/drain cycle again it will work...
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Aug 01, 2011 | Kenmore HE3T Washer
Error code HF
Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet 9100 will not drain during regular wash cycle. Cleaned drain filter & ran diagnostic and then rinse & drain. Water drained from washer & clothes were damp and I thought the...
I would assume that you are using HE detergent if not the pump could go into a suds lock. You may have a bad drain pump. The other options could be possibly a bad central control unit. (however these are very expensive) or possibly a door lock issue but usually you will get a door lock error.
Jan 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Waher stopped with an sud code and will not do anything. water is in washer.
too much suds in washer--
try using HE detergent-
reset to rinse cycle I think will work-been awhile since I had that code-
ready to throw my GHW 9150 off a cliff-FDL codes-door locks up.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenomore Elite HE4t Washer. I am getting an F02 error message. I've tried to rerun washer & get SUDS on and off. Fo2 message appears again and cycle shuts down. Door will not unlock. Any...
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 14, 2009 | Kenmore Elite HE4 Electric Dryer
WHIRLPOOL DUET 9100 STOPPED UP DRAIN IN SPIN CYCLE F02 BLINKS.
I looked up a pic of a model ghw 9100 for you to look at as reference. There is a kick panel with three screws. Either a 1/4 inch socket or a torx T20.
Oct 16, 2008 | Washing Machines
Suds then F02 over and over and over again
Most likely (it happened to many owners), you get the FO2 code, because some small items like socks got sucked into drain system.
Dec 15, 2007 | Whirlpool GHW9200L Front Load Washer
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
96 people viewed this question
Dan Webster
Dan Webster
Sal De
