Question about ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
What is a thermal paste? - ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card
  • 22 Answers
Thermal paste is a substance that assists in thermal conductivity between a heat source and a heatsink. It is used to fill in irregularities that cause air gaps.
http://en.wikipedia.org/wiki/Thermal_grease
Posted on Feb 16, 2009
  • 530 Answers
Hi im josh in cebu phils. may i help you? Thermal grease (also called thermal compound, heat paste, heat transfer compound, thermal paste, or heat sink compound) is a fluid substance, originally with properties akin to grease, which increases the thermal conductivity of a thermal interface (by compensating for the irregular surfaces of the components). In electronics, it is often used to aid a component's thermal dissipation via a heat sink. you can buy this in any pc hardware distributor. i looks lihe an ointment. Good luck i hope i helped you.
How to apply thermal paste to intel pentium p6200?
thermal paste,,or heatsink paste.the paste is on the processer, do not put to much on there just about a match head full in the center of the processer.
Jul 01, 2014 | HP Pavilion 14.0" G41010us Notebook Pc...
Tip
THERMAL PASTE helps
Maybe you have encountered problems like your computer freezes suddenly and you try to find solutions to it by troubleshooting your hardware or software installed. And after troubleshooting for hours and you are 100% sure that all your hardware and software are working just fine.
But you have never tried to look or never guess that between the Heat Sink or CPU has a solution that is put between them to be able to cool the processors/components. It is called Thermal Paste (other names: thermal grease, heat sink paste and etc.).
Thermal Paste helps the cooling off of components and draws heat away from heat sink/cpu. It is really a big help and can increase efficiency in your computer systems.
If you haven't try or see Thermal paste in your computer, try opening your system it is found between your heat sink and cpu, the substance that is applied between them.
It solves computer freezes.
on Jul 15, 2010 | Computers & Internet
Is any problem may occur , without thermal paste in PC ?
Yes, you need thermal paste for 100% and you need good thermal paste for this CPU, this processor is - Thermal Design Power ? 125 Watt
Nov 15, 2012 | Computers & Internet
Cpu over temperature error cpu temp : 39 to 101 mb temp : 30 to 100
First step would be to check all cooling fans are running correctly. Second blow out the dust and debris from inside the computer. If the cooling fans are not running correctly you will need to replace them. Thrid have you added any new hardware or have cables that would interfere with airflow? If so move things around so you have good air flow around the processor. Finally (before we get into the professional portion) you might try adding additional fans to the case, there are fans that will go in a drive bay to help improve air flow.
CAUTION!!!! The following steps should only be taken by a competent professional:
1. Check the heat sink, is there thermal paste leaking out around it (too much paste was used). You will need to remove the heat sink, clean up all thermal paste and then remount the heat sink with a small amount of thermal paste.
2. Remove the heat sink, is the thermal paste dried up? If so, inferior thermal paste was used. Clean up all the old thermal paste with alcohol, replace the heat sink with a small amount of good thermal paste.
Of course if you are running the computer in an 80 degree room, that will affect temperature too.
Hope this helps.
Jul 27, 2011 | ASUS P5LD2-VM Motherboard
Which procesor heatsink and fan can i use for this motherboard
You absolutely must use thermal paste to attach the heat sink to the CPU. If you run your computer without thermal paste, you can ruin your CPU in just a few seconds.
There are many manufacturers of thermal paste on the market currently and each package should have instructions on how to use it. If no instructions are included with the paste, check the manufacturer
Jul 19, 2011 | Computers & Internet
This is a question regarding the Intel processor's internal thermal solution. I have a Core i7 870 processor. As a sidenote I've used it a few times to start the computer and it's functioning, but I can't...
If you have already wiped some thermal compound paste fro the processor then I reccommend you to wipe it completly from the heatsink of the cpu and the heatsink itself. The reason to this is that if you plan on purchasing another type of compound thermal paste in which have more conductivilty then you want to get the most out of it. Do not attempt to run your cpu without any thermal compound as you will damage the cpu from overheating.
Jan 14, 2011 | Intel Core i7 870 / .93 GHz processor...
Thermal Paste
From the word itself it is a thermal paste that can hold the CPU and iot helps out to prevent the heat coming from the processor, when the cpu fan operate/spin it also that helps that processor to cool down.
You may try a toothpaste as a substitute for it you will need a "white base toothpaste" just put only a small amount into it.
Let me know for any clarification
Feb 06, 2010 | Spire STARS-420/2 White grease Thermal...
Power supply to xbox 360
2 red lights on part 1 and 3 indicate the the console is overheating, the most common problem is the thermal paste.
You need thermal paste or it will overheat instantly, using cheap thermal paste or not using enough thermal paste will also cause problems. Use good quality paste and apply enough to make contact. You don't want to use too much, but if you use too little it won't make good contact with the heatsinks.
If you've done this before then it shouldn't take too long, but if you haven't then just take your time. You don't want to put too much on at first so do it bit by bit.
If you're still getting this error after correcting with thermal paste then the only suggestion would be to contact Microsoft but then they might not take the 360 after you have already void any warranty by opening up the console.
Apr 20, 2009 | Microsoft Xbox 360 Console
My laptop keeps shutting off
is the cpu fan running? if its on, then goes off, there is a thermal problem. check for vent blockage. keep it on a hard surface with air vents clear.
Dec 18, 2008 | HP Compaq Presario V2000 Notebook
Think pad battery
apply your heatsink paste in your processor
Sep 11, 2007 | HP Compaq PC Notebook
ASUS EN7200GS/HTD/256M-256MB PCI-E DDR DVI-D TV OUT Graphics Card PCI Express Graphic Card Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
