Question about Maxtor Shared Storage II N01R010 1 TB USB Hard Drive
Maxtor external hardrive will not boot up onto my mac
The lights are on but there is nobody at home!
tried various leads and on two macs plus a `PC' with no luck. No sounds coming from it as there sometimes was... help please???
  • fabpictures Feb 16, 2009
    thanks eric.... as usual you find out they are poo 'after' you bought the bad product!
    cheers mike
  • 33 Answers
Try a more reliable brand. Maxtor isn't. You don't want to take chances with your files!
Here are two options:
1 www.carbonite.com this company will back your computer up automatically for 50.00 a year unlimited.
2 here is a much more reliable external drive at the link below.
http://www.amazon.com/Western-Digital-Essential-External-WDH1U10000N/dp/B000VZCEUI/ref=pd_bbs_sr_2?ie=UTF8&s=electronics&qid=1234779508&sr=8-2
Hope this works for your needs
Please don’t forget to rate me
good luck,
eric
Posted on Feb 16, 2009
Maxtor one touch 4 plus problems: Drive not recognized by my Mac. I can hear the hard drive whirring but the computer thinks it isn't turned on.
You need to determine whether the drive is OK. I suggest trying the drive on another computer before you move on.I trust that you have re-booted the mac? Also try a different cable and USB socket just to be on the safe side.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Feb 21, 2011 | Maxtor OneTouch 4 Plus 500GB External USB...
Installing 1tb External Hardrive from Freeagent onto Macbook Pro
I would be tempted to format the drive using the disk utility whch can be found under applications and then utilities once opened choose your drive in the left hand window and on the right hand side click on erase. If you are using the Seagate drive for the Mac only, format it as a Mac OS Extended (journaled) Choose your volume format and name and then erase. Hope this helps.
Dec 28, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Maxtor manager software shows no drives
First and foremost if you're getting power but not seeing the drive you likely have either a drive or enclosure circuitry failure.
If you have no power lights try a new power adapter.
If the drive has failed and you want the data back you will need a Data Recovery Pro to asist you, if the enclosure has failed it will be much simpler.
Step one take the drive enclosure to a PC shop(no offence to Mac techs but they stink at salvage efforts, must be too many years of promising nothing ever fails ;)). When you get there ask them to remove the hard drive from your Maxtor enclosure and pop it into a generic enclosure(looks cheap but the internals are identical in most cases). Then ask them to test the drive to see if it shows up, depending on how you formatted it they may need MacDisk to make it visable.
If it works, buy the enclosure and head home, you're done. Plug it into your Mac and go on with your day, no harm no foul.
If this fails to see the drive, then the Hard Drive itself is likely at fault, in this case reply to me with your Country, State and City and I will refer you to the closest Data Recovery Facuility with Mac capabilities to have your data retrieved,
Of course if the only data on it is still accesible on the computer and it's a dead drive, just buy a new external, head home and rerun the backups manually as in this case it's cheaper to chuck and replace the external than have it recovered.
Hope this helps FixYa,
Chris
Aug 05, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
Maxtor one-touch mini won't appear on PC
To isolate the problem, please try the steps below:
1. Make sure that the USB ports of your PC are working.
2. Try to connect the device into different USB ports.
3. Try to connect it into different Windows based computer.
Question: Did you reformat this device using your Mac? If yes, there could be a possibility that the device was reformatted using the Mac OSX (Journaled). This type of format would only recognized by Mac computers.
But if it's formatted using the DOS based system, it would work on both Mac and PC.
Apr 01, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
When I purchased the Maxtor oneTouch 4 Plus for my Mac, they sent it to me without disk and manual. It does work, but I have some questions. What is that light on the side of the unit... when I press on...
the light is an instant backup button, you need to have the maxtor softwre installed, but when set up correctly the hard drive will create an updated backup of your mac's hd whenever the button is pressed.
Hope this helped.
Mar 04, 2009 | Maxtor OneTouch 4 Plus 750GB External USB...
Need to dump my data from my mac to my maxtor external hardrive
you need to backup your system using windows back utility on your computer and save the files to your external hard drive.
Good Luck
Jan 19, 2009 | Maxtor Hard Drive
External Hardrive crashed
Try reading this post........http://forums.macosxhints.com/archive/index.php/t-32880.html
Jul 18, 2008 | Computers & Internet
Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Jun 08, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Drive Not Read By ANY Computer
Before installing the Maxtor drive you need to take a backup of the software on the Maxtor. You then need to burn this s/w to a cd to allow you to install the s/w onto any Mac (or PC) you want to use the Maxtor with. If you don't enable the encripted mode then you don't have this problem.
If you didn't take a backup before starting then have a look on the Maxtor site for the correct s/w.
Cheers, robbo
Nov 14, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor Shared Storage  II N01R010 1 TB USB Hard Drive Logo
223 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
