Question about Hitachi Performa CP-RS55 Multimedia Projector
NO power, no lights, possibly there was a flash before it went of
Fuse in plug OK
Lead seems OK
Please can someone tell me how to check or replace the internal fuse or what else can I try
Bulb seems OK
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
The internal fuse is normally located very near the power plug socket and usually a Buss glass fuse, rated 5 amps? If you get to it, check the metal end for the rating.You have to remove the top cover to get at it...remember, the problem could be the fuse--or the power supply section has failed.--Rick
Posted on Sep 07, 2009
DS Lite Will Not Power On
There is a possibility that your battery has developed a short circuit or is so bad that it pulls down the charge voltage on the charger. You are therefore left starved of a power and therefore no function.
If possible, disconnect the battery and run the DS on the charger power alone. If the DS starts to work, I suggest replacing the battery.
Sep 05, 2014 | Nintendo DS Lite
Panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Power steering went out in 1999 dodge grand caravan. Hubby replaced the pump and everything else in that system seems ok, power steering still isn't working.... Only vehicle, please help!!
Have you checked the relays? Fuses? Possibly a short in the wiring or clean all connections in any harnesses related to.. Have you had someone run the obd coses on this? sorry to hear it. its like having a child and never knowing when they are going to fall down.
Do you have the chiltons or haynes manual. Always a good investment
May 29, 2011 | Dodge Grand Caravan Cars & Trucks
Someone gave us a Jet 7 Power chair and we've replaced the batteries and the fuse. I've checked all connections and everything seems ok. but I'm missing something because I'm still getting 2 flashing red...
Assuming it is a P&G controller (it'll say PG Drives technology on the bottom of the joystick), two flashing lights is a left motor disconnect fault. Check the wiring from and to the left motor for tight connections at all junctions. Unplug and replug them, don't just wiggle test them. This should clear the fault.
Oct 17, 2009 | Pride Mobility Products New Pride Mobility...
No power to the spark plugs
Check first the wire connections to your ignition unit. Are they properly plugged? If all wires are good, try to measure the voltage from one of the wires to the ignition unit while the ignition key is in "on" position. If there's no voltage, have someone check your ECM. If there's a good voltage reading, try replacing your ignition unit with a good one.
Jul 10, 2009 | 1994 Suzuki Sidekick
Powerbook G4/17. Had been running on battery, now dead
Hello, You can test your adapter using a voltmeter and see if the power comes in Best regards. The best is actually to test with another adapter
Jun 10, 2009 | Apple PowerBook G4 Mac Notebook
No power to radio after new battery installed
It sounds like you had a power spike when you installed the new battery. I would check the 2 factory fuses for the radio, one will be for the radio ignition lead and one will be just battery lead (usally assosiated with the clock). Lastly if those 2 fuses were ok you may have to pull the deck and check the fuse in the back of the deck.
If the fuses are all ok and no wires are disconnected, then its possible that something else went out. Good luck and take care!
Jun 03, 2009 | Pioneer DEH-1900MP CD Player
Dell Latitude CPi has no power and lights will not come on when connected.
If you bought a new battery and connect the powercable and still nothing happens it's usually a problem with a fuse. If not a fuse it's usually the cpu. If the problem is with the vga the lights usually turn on. Difficult problem. This depends on how fare you want to go and able to spent.
good luck
Nov 28, 2007 | Dell Latitude C610 Notebook
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Hitachi Performa CP-RS55 Multimedia Projector Logo
353 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
