Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Triple color on screen
Three color donot match . the screen look like defective conversion. This problem require mechanism adjust or service mode adjust or must replace complete of the Engine light unit
  • 1 more comment
  • lsoare Feb 16, 2009
    Cleaned all mirrors in ushaped light tunnel. Now colors do not line up there must be a way to align by ajust ment. Help.. I can disasemble and reasemble with my eyes closed. lol
  • Joe1974 May 11, 2010
    Sounds like a convergence problem. I can't really give you a definite answer without a picture of the problem. I can tell you that the site that Jean posted will not fix this
    problem and could even make things worse. That site pertains to a specific problem that is common in
    some Sony sets and should not be used to try to fix any other issue.
    Please keep in mind many things can go wrong with TV
    sets and you should really do a lot of research before attempting any
    adjustment and or repair. There are high voltages present in some areas and they can
    reside even when the set is unplugged.
  • ladywinn
    ladywinn May 11, 2010
    IS YOUR TV DLP/LCD or Projection has 3 TUBES R/G/B?
    Scholar:
  • 29 Answers
Http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
This blog covers many makes and models with many issues solved, just with that one solution
Give it a try, it's free and simple :D
Hope the blog helps you.
Jean
Posted on Mar 12, 2009
Screen is stuck fully expanded on startup screen
Maybe you have turned on the Zoom settings from the Accessibility menu. To zoom out, Triple tap the screen with three fingers until the screen zooms out. To disable Zoom, go to Settings > General > Accessibility, look for Zoom then click to disable.
Tips for Zoom:
- To zoom in or out, triple tap the screen.
- To adjust the magnification of the screen, press and hold with three fingers, then scroll up and down to change.
- To navigate the screen, swipe using three fingers to left, right, up or down.
Hope it helps!
Cheers!
-Josh
/uploads/images/screen-stuck-fully-expanded-startup-35310085-5-1.jpg
Mar 27, 2015 | Apple iPhone 5c
Tip
SERVICE MODE AND POWER SUPPLY ADJUSTMENT
FUNAI LED40-H9200M
White Balance Adjustment
Purpose: To mix red and blue beams correctly for pure white.
Symptom of Misadjustment: White becomes bluish or reddish.
1. Operate the unit for more than 60 minutes.
2. Set the color analyzer at the CHROMA mode and zero point calibration. Bring the optical receptor pointing at the center of the LCD-Panel.
3. Enter the Service mode.
4. Press [ VOLUME -- ] button three times on the remote control unit to select "Drive setting" mode. "Drive" appears on the screen.
5. Press [3] button to select the "HDB" for High Drive Blue adjustment. ("HDB" appears on the screen.)
6. Press [MENU] button. The internal Raster signal appears on the screen. ("Internal (Single)" appears on the upper right of the screen as shown below.)
7. Press [P UP /DOWN ] buttons to adjust the color temperature becomes 12000°K (x= 0.272 / y= 0.278 ±0.002).
8. Press [1] button to select the "HDR" for High Drive Red adjustment ("HDR" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
9. If necessary, adjust the "HDB" or "HDR" again.
10. Press [6] button to select the "LDB" for Low Drive Blue adjustment ("LDB" appears on the screen.) and press [P UP/DOWN ] buttons to adjust the color temperature.
If you wish to get some details; check the site linked here. Pull up older posts
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 21, 2015 | Funai Philips 40" LED Wifi IPTV - Black...
Tip
ERVICE MODE AND POWER SUPPLY CIRCUIT
SERVICE MODE AND POWER SUPPLY CIRCUIT
Purpose: To bring the color adjustment of each component into standard alignment.
Symptom of Misadjustment: If this adjustment is incorrect, component signals do not reproduce the corresponding color.
1. Input 1080i 100% Color Bar signal.
2. Enter the service mode.
3. To enter the Auto Calibration adjustment mode, press [6] button on service the remote control unit.
4. To start auto adjustment, press [1] button on the service remote control unit.
- In the auto adjustment mode, "Please wait" appears on the screen.
- Upon completion, "OK" appears on the screen.
TO KNOW MORE CHECK THE LINK BELLOW
on Feb 18, 2015 | Emerson Used Original LC195EM82 Remote...
I have a toshiba tv model tp50g90 I have replaced the convergence chips stk392-110 convergence was corrected but I have a problem yet red not managed to focus on the user menu in the option of...
Thats the way it works. You have to adjust the other colors to the red. You adjust the red from the back of the set using the convergence magnets on the tubes. Then you adjust the other colors to match the red. It's much easier if you have the plastic screen from Toshiba used to align this set.
Feb 20, 2011 | Toshiba TP50G90 50" Rear Projection...
Convergence problem
This is out of the service manual
don't forget to write the setting to rom by hitting the pip button twice
Good luck and don't hesitate to ask questions
2.12.5 Convergence point adjustment
Adjustment preparation
(1) Select color to adjust.
“STATUS” - Green
“0” - Red
“ANT” - Blue
(2) Use 4, 6, 2, and 5 to move the cursor position
(dotted lines).
(3) Use thumb stick to move the convergence point.
(4) Three adjustment modes are available:
1. (3x3) Press “STATUS” 5 times (only works
when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
For touch-up, only the (13x9) mode is necessary.
This will adjust every cross-hatch intersection point
on the screen.
For complete adjustment, start with (3x3) mode. This
will adjust center point and eight edge points only,
but will greatly reduce adjustment time. Then use
(7x5) mode, and finally (13x9) mode to finish
convergence.
If “S” distortion appears between cross-hatch lines
repeat (7x5) mode to change calculation process
while adjusting to remove distortion, then return to
(13x9) mode to finish touch-up convergence.
Adjustment procedure
(1) Receive any NTSC signal.
(2) Start adjustment at the center of the screen.
(3) Continue adjustment at next closest position.
(4) Adjust center area first, ending with edge sections.
(5) Press INFO button to perform calculation operation.
This process will take about 2 seconds and no
picture will be seen at this time.
(6) After interpolation, check convergence again and
repeat (1)-(5) if necessary.
(7) When convergence is acceptable, press PIP MODE
to write data to ROM memory. ROM WRITE? is
displayed to alarm system that ROM will be
overwritten with new data. Press the PIP MODE
button again to write displayed data to ROM.
(8) DATA WRITE TO ROM will take approximately 4
seconds and no picture will be displayed.
(9) Green dots will be displayed when operation is
completed.
(10) Press MUTE to return to convergence pattern, then
confirm again convergence is acceptable.
(11) Press PIP MODE (ROM WRITE) mode, then press
PIP CH to initialize sensor data positions.
(12) Input any 1080I signal.
(13)Press EXIT key 5 times to exit video mode.
(14) Select an input with 1080i signal.
(15)Access menu and select ASPECT 5 mode.
(16)Press the SERVICE SW. ONLY button to enter to
DCU crosshatch signal.
(17)Repeat steps 2~11 above.
Notes: (1) Display only green for easier adjustment and
match to jig screen. Press “MENU”, THEN
PRESS “STATUS”.
(2) Perform interpolation and data write to ROM
after green adjustment. Once green has been
confirmed to match jig screen, the jig screen can
be removed. Do not readjust the green color
after jig screen has been removed. This is now
your reference color.
(3) Display green and red only and match red to
green.
(4) Display all colors and match blue to green and
red. Touch-up red color if necessary.
(5) Existing DATA in ROM can be read by pressing
the SWAP button 2 times. This data can be used
after replacing a component (CRT, DY, etc.)
Where complete convergence adjustment is not
necessary, be careful not to overwrite this data.
DO NOT write cleared RAM data into ROM or a
complete convergence adjustment will be
necessary. Remember to try MAGIC FOCUS
before starting convergence adjustment to
minimize adjustment time.
Feb 01, 2009 | Hitachi 53UDX10B 53" Rear Projection...
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Projection defect
Good Day;
It sounds like you may need to re-adjust your G-2 controls, located at front, remove front panels. Look for small block with screen /focus controls on item, first turn color down, reset brightness, contrast controls. Adjust until lines are at min. and picture is a good black and white (grays). Good Luck, big IRISH.
May 21, 2008 | Panasonic PT-52LCX65 44" HDTV
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Triple picture and purple bubble on big screen
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Sep 25, 2007 | Sony KP-48S70 48" Rear Projection...
Colors won't stay set
NOTE: Manual Convergence settings ARE LOST if the customer returns to AUTO Magic Focus mode. (More Details) this situation is normal. Bottom line: This is caused by two issues, The Centering is off of any or all CRTs. (Don't forget Red and Blue Offset values). The Horizontal Size needs to be changed by increasing H. Size by 20mm. Readjust the Horizontal Size to the NEW specifications. These are different that the original Service Manual. They have been increased by 20mm on 51", 57" and by 25mm on the 65". Before replacing DCUs, Please CHECK and confirm if any of the three color center alignments are off and readjust the Horizontal Size to the New specifications.. TO CHECK. Clear DCU data by holding down the DCAM "Service Only Switch" and then POWER. Make sure the Green is centered. Make sure the Red and Blue is offset from center with respective offset value according to the SM information. Readjust the Horizontal Size to the NEW specifications. These are different that the original Service Manual. They have been increased by 20mm on the 51" and the 57" and on the 65" it's increased by 25mm. There IS NO NEED to replace DCUs. The DCUs are not defective...All that is needed is to confirm the Centering Adjustment for the three colors and adjust the Horizontal Size to the NEW specifications. Adjust if any color is found to be out of adjustment specifications. If you don't understand this then you need live chat!
Sep 11, 2007 | Hitachi 43F300 43" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
213 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
