Inability to detect memory
My Asus Motherboard Model P4S533-E has a total memory of 512MB (256MB x2). Upon powering up the cp it only detcts 256MB. I tried to removed the other module just to check which module is the problem but it doest work (NO POST), I do the same with the other module in other words one module at time but the result was the same NO POST. I returned back the two modules then POST going on but showing only 256MB. To my knowledge supposed to be work with one module. Please help!!
  • 530 Answers
Hi im josh in cebu phils. may i help you. i had encounter the same problem of yours before. with that knowledge, there are times it will not detect if you dont have the same brand of memory.be sure you are using the same brand to avoid problem.or one of your memory bank is not functioning.try to clean it.using a brush. good luck! i hope i helped you.
Posted on Feb 16, 2009
Upgrading from 64mb card into 128mb or 512mb card. should i remove the component (64mb card) from motherboard? pls help. thanks.
Maybe you are referring to the video card? Or even RAM? If it is RAM you should definitely be using the 512MB (4 X 512) by this time. It is an older board, an ASUS (USA) no longer has a detailed specs webpage for this model. Make sure to check your manual.
Found this one:
http://reviews.cnet.com/motherboards/asus-p4s533-x-motherboard/4507-3049_7-30641017.html
Sep 29, 2012 | ASUS P4S533-X Motherboard
PC memory? Im not sure what I can use
Are you sure you have the correct model number? Because that model number should only have 2 Ram Slots located right below the processor slot. I put a picture of the ASUS P4S533-VM motherboard at the bottom of this answer for you to check.
If that is the correct motherboard model number then it takes up to 2GB of PC2700 DDR333 Ram (2 sticks of 1GB PC2700 DDR333 Ram)
Here is a copy of the user manual for your motherboard:
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4s533-vm/e1058_p4s533-vm.pdf
May 21, 2012 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Is it okay i would like to shift 64mb vga to 512mb vga? p4s533-x
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Mario Quejada.
Your ASUS p4s533-x mainboard supports graphics cards using the AGP X4 slot. Therefore you may install a graphics card with any memory size so long as it uses the AGP X4 slot interface.
Take care!
Dec 17, 2011 | ASUS P4S533-X Motherboard
I have an asus m2n mx (windsor) motherboard and an amd athlon x2 3600+ processor . . . i have a pair of 667mhz 512MB (total 1GB) ram and a pair of 800mhz 1GB (total 2GB). . grand total(3 GB) . . My problem...
The manual for your motherboard states:
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
Sep 11, 2011 | ASUS M2N-MX Motherboard
Is there any specific memory card brand and value for ASUS P4V533-MX? I want to upgrade my computer's RAM from 256MB to 1Ghz, I bought two DDR1 512MB surplus memory cards with different brand name, neither...
This mother board Support only DDR333 PC133 SDRAMS. Check the lebel of your newly bought memory modules whether it matches or not. If not then you should replace them.
Mar 15, 2011 | ASUS P4S533-MX Motherboard
ASUS P4S533 Motherboard type of ram to add
Your "ASUS P4S533" model motherboard has three DDR SDRAM DIMM sockets.
You can install any DDR DIMMs with 64MB, 128MB, 256MB, 512MB and 1GB into the three DIMM sockets shown in the picture below. Total system memory can be max. 3GB.
You can see the listed qualified DDR333 memory modules in the picture below and use any of them with your motherboard. Also you can check the ASUS website for the updates.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 10, 2010 | ASUS P4S533 Motherboard
Windows 7 detects my video card which is xfx geforce 8400 se having a 512mb but only detects as 256mb video card?
When you turn on your pc press F10/F2 (depends upon the motherboard manufacaturer) to go to system setup, function will be according to the motherborad, check for an option named APG/APG Memory/Video Memory. and replace its value using up n down keys or page up/page down or +/- keys. and choose 512 value and maximum value is 256 or less than 256, your motherboard does not support the video memory more than it is selected.
Nov 28, 2009 | Pine Technology XFX GeForce 8400 GS /...
Adding memory to Asus p5v800-mx motherboard
if they are compatible with your motherboard, different versions of RAM do not conflict
May 04, 2009 | ASUS P5V800-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
Computers & Internet Logo
46 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
