Question about Sharp Aquos LC-32D40U Television
Horizontal line in My SHARP AQUOS LCD 32'' TV...
When I watch analog input channels (cable TV connection) in my LCD TV, a horizontal line is moving top to bottom on the screen. The problem does not come in tata sky input. Can you please help me to resolve the problem. If it is for voltage fluctuation and grounding problem then what is the way out?
  • Anonymous Feb 17, 2009
    i have the same problem. returned a tv today because of it and bought another and it is doing the same. also, both had a humming when the sound is low you can hear it and it is annoying. so far I have seen these problems on the well known brands, as well as store brands.
SOURCE: Horizontal green line appears on screen
my maxent plasma tv has the same problem but it has green and red lines. I found out that hitting the tv from the back works. It used to last a long time but now i have to get up now and then to slap the tv on back with my hands! anyone with a long term solution?
Posted on Jun 12, 2008
SOURCE: turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Posted on Aug 23, 2008
  • 346 Answers
SOURCE: Blue horizontal and vertical lines
poor convergence
Posted on Nov 12, 2008
  • 5 Answers
SOURCE: Horizontal line in My SHARP AQUOS LCD 32'' TV screen
Try to conect with DVD signal in A/V input if good picture, cable line are no good
Posted on Feb 16, 2009
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
May 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I BROUGHT A USED SHARP AQUOS TV I CAN'T GET IT TO SEE MY CABLE KEEP SAYING FAIL TO RECEVE BROADCAST
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Dec 15, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Picture no sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 18, 2009 | Sharp LC-C4655U 46 in. LCD TV
Feb 16, 2009 | Sony 32 in. LCD TV
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
234 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
