Question about Homelite Mighty Lite Lawn Trimmer
F2020 lime trimer has no spark, yes the switch is on.
Have replaced the spark plug and not the slightest spark can be seen.
  • Anonymous Apr 03, 2009
    lost instructions manual for F2020 HOMELITE. wHERE CAN i FIND ONE ON WEB?
  • toddamantia Apr 12, 2009
    I have the same problem....I used wire to attach to engine block from spark plug and other end of spark plug was in the boot as advised. Any other solutions of how to get it to spark of if something needs replaced. Spark plug wire is in great shape....
How do I start an homelite whipper snipper model f2020 this one I have never started from new it's about 3 years old could be older it's never even had any fuel in it up to now
First make sure the on/off has tried in both directions. Even here in the shop I sometimes forget to set those switches that don't have the momentary off postion.
Then if still doesn't start then I would treat it as if run at sometime and go thru the basic troubleshooting of a won't start engine.
  • Check for spark. No equals ignition problems.
  • If you have spark then
  • Try putting a little fuel mix in the cylinder via the spark plug hole to see it will try to start. if tries to start then carburetion problems. Yes even with an used carburetor.
  • If still don't try to start then check for compression and timing related problems.
Jan 06, 2015 | Homelite Garden
String trimer
Sounds like air in the system, take spark plug out, pump bulb 3 or 4 times, replace spark plug and try to start. Repeat.
Apr 17, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
31cc poulangrass trimer/no spark at spark plug
The magneto is most problably broken or cracked
. its the little box where the plugwire comes from.
Apr 10, 2014 | Garden
Apache quad rlx250 ax
just guessing that you have already changed the spark plug??!! Handlebar on/off switch in the on position? (yes, I have seen this come to the shop). After this you need a shop manual to check wiring connections, resistance values..etc.. if not... might be shop time.
Mar 28, 2014 | ATVs
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Lawn trimer repair shops surrey/delta ..c.
Carb switch coil gas,gas lined primer bulb spark plug. Start with carb cleaner in the intake. If it starts move to carb.
Mar 09, 2013 | Toro 15" Electric Trimmer&Edger
Homelite trimmer F2020
One of the most common failures would be the smallest air leakage in the pickup tube. the siphon effect is cancelled by an air leak too small to see. If the trimmer will start momentarily or "pop over" when fuel is administered directly through the venture or spark plug hole then the issue is definitely fuel delivery. bad diaphragm, swollen fuel lines or a blockage in the main jet or venture tube.
Oct 24, 2017 | Tools & Hardware - Others
My trimer dont' have spark wen y pull the rope
pull the the kill wire off at the kill switch or button make sure wires cannot touch earth - retry for spark , check ht lead for grounding somewhere if ok try new plug if still no spark - replace ignition unit then reconnect wires
Aug 03, 2010 | Craftsman 25cc Gas Line Trimmer
How do i change the spark plugs on a 2003 kia rio
INSPECTION
1. Disconnect high-tension code from spark plug.
2. Remove the spark plug.
3. Connect the spark plug to a high tension code.
4. Hold the spark plug with insulated pliers 5~10mm from a ground.
5. Crank the engine and verify that there is a strong blue spark.
If there is no spark, inspect the following points.
Step Inspection Action
1 Check for good connection of ignition coil Yes Go to next stop.
No Repair or replace
2 Check if resistance of high-tension leads are OK Yes Go to next step.
No Replace
3 Check if the ignition coil is electrically charged
1) Ignition switch "ON"
2) Check if the engine coil (+) is electrically charged
Yes Go to next step
No Check the wire harness between ignition switch ignition coil and ECM
4 Check if resistance of ignition coil is OK
Resistance
Primary : 0.36~0.44Ω (at 68°F (20°C))
Secondary : 10.9~13.3kΩ (at 68°F (20°C)) Yes Go to next step
No Replace
5 Check if ECM is OK Yes
No Replace
REMOVAL
Do not attempt any maintenance on spark plug if engine is hot.
1. Disconnect negative battery terminal.
2. Carefully remove high-tension leads.
3. Use compressed air to blow any dirt or debris from around spark plug hole.
4. Check that spark plug fits squarely in spark plug socket and remove spark plug.
Raise a vehicle and install SST(OK552 131 001) in order to replace cylinder 2, 4, 6 spark plug.
INSTALLATION
1. Install spark plug into cylinder head.
Tightening torque : 18~22lb-ft (25~30N·m, 2.5~3.0kg-m)
2. Reconnect high-tension leads.
3. Reconnect negative battery cable.
Jul 17, 2009 | 2002 Kia Rio
Homelite Mighty Lite Lawn Trimmer  Logo
545 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
