Question about Sony 32 in. LCD TV
Horizontal line in My SHARP AQUOS LCD 32'' TV screen
When I watch analog input channels (cable TV connection) in my LCD TV, a horizontal line is moving top to bottom on the screen. The problem does not come in tata sky input. Can you please help me to resolve the problem. If it is for voltage fluctuation and grounding problem then what is the way out?
  • arijit1001 Feb 16, 2009
    I understand.thanks
    Problem Solver:
  • 5 Answers
Try to conect with DVD signal in A/V input if good picture, cable line are no good
Posted on Feb 16, 2009
  • 4 Answers
In LCD TV H-LINE MOVING TOP TO BOTTOM ,This fault is due to (1)rusty connectors of inside the LCD.(2) your TV is running in comercial aira i;e grander, mixer,flur mill ,drillmachine works near by you.
Posted on Oct 23, 2012
    Problem Solver:
You try to conect with CRT tube TV .If TV still same that Cable line need the special filter or call the cable company.if TV has good picture ,the LCD TV have leakage on power supply or tuner
Posted on Feb 18, 2009
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
How do I fix my Sharp tv model LC-42D62U? On the tv screen now shows horizontal lines with repeating ghost images.
Hi Paul,
The horizontal lines on the screen are virtually NEVER caused by a bad T-con board. These horizontal lines indicate a defective LCD panel (screen). The Screen has small ICs that become defective overtime and that it isn't fixable unless replacing the entire screen.
Sep 13, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos horizontal streaks
A loose contact at the sockets to LVDS cable, that connects its T'Con board to display panel will show this kind of fault on screen. Check it. If you wish to get more details about it, check the link sited here. http://electronicshelponline.blogspot.com/ It has illustrations and descriptions about the faults that occur to LCD TVs. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 26, 2013 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Want to run Dish network DVR 2nd TV thru cable to Sharp lc-c5255u Dish uses channel 73. It was not on my TV. I did a channel search and it did not find it. It also erased all channels and I can't...
Go into the setup menu and do a channel search again selecting digital and analog channels. Then change the input type to cable and you should get your channels back.
Aug 31, 2011 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
How do I connect an analog antenna to a 32 inch sharp aquos tv? and do I need a specific input setting?
antennas are not analog or digital, just VHF, UHF and they typically connect to a RF coaxial jack on the TVs rear panel. 75ohm silver round jack. Select in your TVs menus, AIR when you want over-the-air TV stations and do a new channel scan to pick up local channels.
May 06, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I BROUGHT A USED SHARP AQUOS TV I CAN'T GET IT TO SEE MY CABLE KEEP SAYING FAIL TO RECEVE BROADCAST
How are you connecting it to cable tv?
If you are using a coaxial cable to a cable box you have to turn to channel 3.0 with a Sharp remote by pressing 3.0 enter the dot (.) is down by the 0. There is a way around this if you don't have a Sharp remote. You can go into the menu and complete a channel scan. If the model you own is the one pictured then you should have the coax cable connected where it says analog if you are connecting to a cable box this way.
If you are using composite, component, or hdmi cables you press the input button on the television and pick the right input. It is recommended that you do not use the coax cable anyway unless you do not have a cable box. There is an input button on the television and on the remote.
Dec 15, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Picture no sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 18, 2009 | Sharp LC-C4655U 46 in. LCD TV
Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Jun 04, 2009 | Sharp LC-46D64U 46 in. LCD HDTV
Blue horizontal and vertical lines
We have many problems with loose or poorly seated cables and connectors on these units. Pull the back and reseat all the internal cables, especially the LVDS cable to the LCD control bd. If this does not correct the problem the main cause is a bad LCD control bd. or possible a defective main bd.
Jan 12, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony 32 in. LCD TV Logo
968 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
