Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Can't get abc, 7, 9, 10 sbs, tvs on awa stb 262
I have purchased a AWA set top box 262 today, and after allowing it to do it's own set up, it has a programme list for the normal free to air channels, but i can't get to them.. it has ACC, Nitv... and many more and gives times for abc, 7,9,10, sbs, tvs..... but i can't figure out how to get to them... i have tried to tune it aagin, and finds 14 channels... but not the normal ones.. is this solvable or do i need to ditch it????????????
  • 4 more comments
  • Anonymous Mar 19, 2009
    know the feeling
  • Anonymous Mar 23, 2009
    mine only shows channel 7, 70, 77 and i can't find where to autotune it.. (the menu button doesn't seem to work)
  • Anonymous Mar 27, 2009
    Mine shows 9, 90 and 99, also menu button dosn't work, these things are rubbish
  • annettenish Apr 12, 2009
    can't get channel 10, ABC or SBS
  • bazza12345 Apr 26, 2009
    I can only get 7.
  • deanwhitaker May 15, 2009
    I get 7HD, 7, 9HD, SBS but no 10, One HD or ABC 1 or 2. I have left msg sat morning with AWA Hotline but dare say given the software is dated June 2008 it will need an upgrad via the r232 port which means return to AWA service centre. Dean
Need a manual or connection diagram for a AWA set top box Model No. 2030
Hi Anonymous, The link below is a FREE 10 page user manual for an AWA digital set top box model number 2030..........CHEERS..
http://cncms.com.au/AWA-IMs/SetTopBox/DT2030.pdf
May 02, 2016 | Televison & Video
Tuning AWA television with no remote?
Universal remotes don't do all the functions that a manufacturer remote do not
http://www.tvremotes.com.au for remotes in Australia
If you use a set top box tuner the TV will become the monitor and the box will become the tuner and use one of the rear or side video inputs and bypass the internal tuner and just programme the stb remote to set the TV volume to the desired level
The above link may have the remote you want but as I am in the UK the server blocks me
Sep 01, 2015 | Televison & Video
AWA tv code
0281,0288. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name only of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 08, 2015 | Televison & Video
Akko
http://www.awa.com.au/AIKO---Set-Top-Box/default.aspx
You can download the manual here. The factory reset is within. If you don't find it, let us know I will tell you how. Best to look for yourself as your set top is a diff one than mine and I want to be sure.
Jun 10, 2013 | Computers & Internet
AWA STB 262 doesn't work properly
bennoanddash
With all receivers, depending upon the type cable going from the receiver to the TV, the TV is set either to a channel or an input setting (if using any cable other than a coax cable). I hope this helps.
Ray Calo
DISH Network
Nov 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Unable to rescan channels AWA STB 262 set top box.Need to scan for lates channels. Menu button not working. AWA HD Digital Terrestrial Receiver Model STB 262
These STB262 box remotes won't work if they are not hooked up with the 720dpi option (Use HDMI Cable) -
Cheers - compac
Sep 01, 2009 | Televison & Video
We cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Aug 24, 2009 | Televison & Video
Awa dvd recorder dr711 can this be connected to a set top box
If it's like the DR620 it will only receive analogue from the TV aerial. I connect the AV out connections on my set box to the inlet AV on the recorder and watch and record through the recorder's "rear AV input" selection.
Jun 16, 2009 | Durabrand DVD-1002 DVD Player
How do you connect AWA plasma TV to AWA surround sound
Hi Map33_bm
It appears that your TV set is 2 channel stereo, so as there is no surround signal coded into the TV audio channels, thesurround sound does not process it.
I've posted a PDF in 'manuals' which you can check out.
Did this info help at all?
Regards, Clive.
Oct 28, 2017 | Televison & Video
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
1,321 people viewed this question
Top Sagem Televison & Video Experts
Andy Fraser
Andy Fraser
electracon
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
