Question about Brita 35516 Pitcher
Too much carbon in water
I started noticing a lot of dark specks (carbon, I presume) in my Brita-filtered water. Although I didn't think the filter was in need of changing yet, I decided to go ahead and change it. I was still noticing tons of carbon, even more than before (both in the upper portion of the Brita and in the water itself (though to a lesser extent). I don't remember it ever being like this in all these years. I changed the filter yet again, thinking maybe I had a bad filter. Same thing. I followed the directions with the filters, soaking them and then letting out the first couple of gallons. But I continue to get tons of carbon chips in the upper portion of the Brita and more and more in the water. In fact, I just looked at the bottom of my water and it was filled with large carbon chips and smaller, sand-like black chips. It's not my water - it's coming from the filters. I have no idea what to do.
  • johnnylimo Apr 04, 2009
    I have exact same problem but I am unaware how to fix. I didn't buy the brita to put more garbage in my water. I thought it was just a bad filter and was going to just change it but the other user indicated he tried and had same problem with the replacement. The solutions indicated possible bad BATCH of filters? How is this possible? Return them to brita for analysis? Yeah and I bet they'll reimburse me for the postage and the filter and my time and all the carbon i have been injesting for the past three weeks.
  • 134 Answers
Sounds like a bad batch of filters. Stop using them and return them to Brita for analysis and replacement
Posted on Feb 16, 2009
Brita filter
When you initially soak the bag in water make sure to squeeze it lightly and shake to release all the air bubbles. Also, you should pour out the first couple pitchers of water after using a new filter as it takes time to break in. This way all of the gray or black filter water will be gone by the time you wish to drink. For more water filter and pitchers go to www.freshwatersystems.com.
Jul 09, 2014 | Water Filters & Coolers
What is the difference between a water purifier and a water filter?
The main difference between the two is that water filters only remove parasites and bacteria from water, while purifiers removes these as well as potential viruses.
Aug 26, 2012 | Brita Camping, Backpacking & Hiking
Which water filter is better, sediment or activated carbon filter?
I can tell you that they are both considered to be very good water filters. Due to my personal experience with the both of them I advise you to pick the activated carbon filter, it is a bit more expensive than the sediment but I last more time and live much less scale in your water.
Aug 23, 2012 | Brita Camping, Backpacking & Hiking
What are the different types of water filters?
There are two main types of water filters, the sediment and the active carbon which sometimes they are combined into a single unit of.
What is the purpose of water filters?
The main idea behind nearly all water filters is keeping the contamination out by trapping them within the filter matrix by attracting them to the surface of carbon particles or by screening them out with very small pores.
Does the distillation process purify contaminated water?
If you do the distillation process exactly right it is almost 100 percent safe to drink the distillated water. Although it is very difficult to do it right and the distillation process is very slow and consumes a lot of energy therefore very expensive.
When I pour water into Brita pitcher I always get a lot of sediment or whatever it is from the replacement filters. I tried pouring different ways but not much of a difference.
From the description of this model's replacement filters, they appear to be carbon filters. What you are seeing is most likely bits of carbon granules from the filter media (which doesn't say much for the construction quality of these filters). I would suggest getting an inexpensive countertop or under-counter filtration system instead of using Brita pitcher filters. These systems usually come with both carbon and sediment filters and if you get a non-proprietary one (i.e. not a system off the shelf at Lowe's), the filter elements are a lot cheaper to replace.
Aug 16, 2010 | Brita 35516 Pitcher
Filter not filtering
When you put the filter in, did you let several gallons of water run through it before you started using it for your own use? You're supposed to flush the filter (see directions on box filter came in) before you use the filter for your own purposes.
If you're getting "chunky" water, check to make sure the water coming in from your taps is not sketchy, that your water source (either town/city or well) isn't encountering problems. If that's the case you might need to put in a "whole house" filtering system.
Aug 28, 2009 | LG LRFD25850 French Door Refrigerator
Brita 35516 Pitcher Logo
1,179 people viewed this question
Top Brita Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Brita Water Filter and Cooler Expert? Answer questions, earn points and help others
