Question about Cfm Daikin R410a Split System Air Conditioner
Fan coil unit won't cool or heat in room1 while room2 runs well
I have a daikin multi split inverter system with two coil fan units and 1 outdoor unit. Fan coil unit 1 does not cool or heat- just blows air, while fan coil unit 2 works very well. The coils have been switched over, this gave a reverse effect, room1 is ok now but room 2 justn blows air.
anyone has an answer for this. thank you
  • Anonymous Mar 19, 2014
    fan & coils work
    Problem Solver:
  • 6 Answers
Could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
Idec inverter e3 problem
This is stating that there has been a high pressure error on this system.
This could be due to fan motor or air flow problems with the condensing unit, but it could also be an issue with the high pressure sensor or switch
Oct 23, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Cfm Daikin R410a Split System Air Conditioner Logo
906 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Brett Duxbury
Brett Duxbury
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
