Question about Black & Decker Garden
How to reassemble switch mechanism
Cannot find the correct placement of the switch mechanism
2 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: placement of switch mechanism
Go to www.toolpartsdirect.com and in the search box select brand and enter your model number and you should be able to find a break-down of your machine which will give you an idea as to how it goes together.I tried the GT249/H1 and GT249 as the model number and it didn't come up so you will have to look for a tag with the model and serial number on it for the correct number.
Posted on Mar 02, 2009
Reassembling Graco Spree
Hi Laura,
We would recommend you contact Graco for assistance.
Contact Graco
Jan 31, 2014 | Baby Gear
Where is the correct spot to put the magnet on the spoke for the v12 mini
The only placement requirement for the magnet is that it pass exactly next to the sending unit you mount on the fork (there is usually a mark on the unit). So, really the placement of the sending unit determines the "correct" placement of the magnet on the spoke.
May 09, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
Poor washing
Tear down the lower spray arm mechanism to the deck, noting placement and orientation of each part as removed. Look for cracked/split plastic while you do this. At the bottom, you should find a large screen that is likely plugged with food and water deposits. Soak it in a solution of hot water, detergent, and white vinegar for about an hour. Scrub it if necessary to get the screen clean and open. Clean any openings in the deck of food deposits. Reassemble everything in reverse order. Inspect and clean all of the spray arms (the small holes), and look for any split seams in the arms. Hope this helps!
Dec 26, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Dishwasher pumps water into it but will not wash. Sounds like something is turning underneath but still nothing?
Tear down the lower spray arm mechanism to the deck noting placement and orientation of each part as removed. At the bottom, there should be a large screen that is probably pretty well plugged--soak it in a solution of hot water, detergent, and white vinegar for an hour or so. Scrub the surface with a brush to help dislodge water and food deposits. Inspect all openings in the deck for any food deposits. Check the pump mechanism to see if it is attached to the motor properly. Reassemble in reverse order. Check the spray arms for any plugged spray holes and for any split seams. Hopefully, this will restore operation.
Dec 19, 2009 | Washing Machines
1987 MSD Distributor Cap Sparkplug Placement Help
First you need to determin witch one is #1 on cap Witch usely is the one directly behind carb. or throutle body. than its perty strate forward from there rotor runs clockwise. Cap only goes on one way. Food for thought when you chg. cap or wires one at a time is the rule even for a seasoned mechanic.
May 04, 2009 | 1987 Chevrolet Camaro
Placement of switch mechanism
Feb 16, 2009 | Black & Decker Hedge Trimmer
Power Nozzle reset
if you mean the reset breaker that just has two wires on it, then you can place them back in any order, there is no polarity
Jul 27, 2006 | Electrolux Epic 6500 Vacuum
Garden Logo
64 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
