Question about LG LS-L1210CL Mini Split Air Conditioner
DERAIN PROPLEM HWO WE CHECK DERAIN AND OPEN CASSETT UNIT
  • 30 Answers
Open Front Grill cover By using Perfect tools and at the corner of the indoor Unit you will find Rubber Cap Drain Stored Water after that open Evaporator Coil Pannel Same location you ll' find Drain Pump Motor Checked out Hope so you have done
THX
Posted on Feb 16, 2009
Change cassett radio to cdradio
NO-- it cannot be by passed as it is in the program of the unit If you cannot get the code you have wasted your money in the wreckers . I would suggest that you get a unit from a radio shop and have them install it for you and then it will work properly with no car problems.
Jan 04, 2014 | 1998 Cadillac Eldorado
I have received mms on my aircel no fron http://mms.live.vodafone. in hwo ill i see it?
Aug 18, 2012 | Lands Phones
Hi i have a panasonic cs28 cassett units both have F27 01 fault codes. have checked power at indoor and outdoor units can i do anything else
f27- indoor outdoor unit disconnected.
Check power in output of indoor and input of outdoor, if power variation, replace wire.
Normally in this fault code, one of the wire burnt or rat bitten.
Dec 27, 2010 | Heating & Cooling
My printer display saids to "remove and check right cartridge" i've done that several times, no respond. help!
I had same problem with different printer usually new print cassets can be slow starters. I tried make sure the strip is full off the new cassette also the ink apperture is open use a nail.
Run machine head clearing routine. If all this fails change cassett Good luck!
Nov 11, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Hwo can i solved a bineary search problam in c++
first arrange your array in ascending order.and keep the two variables one for starting index and one for last index
then check your number with center(center = (first index + last index))/2 element of array.
if it is lager then center element then set first index = center,
if smaller then last index = center
else you got the number..
Jul 25, 2010 | Borland Turbo C++ Suite 1.0...
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
FRT 18 DR HWO the compressor will not work. Fan
This could be for a couple of reasons. The compressor itself could be bad. The relay and/or overload could have burned out. I have seen just simply a wire has come unplugged. You will need to *UNPLUG* the refrigerator from the wall, remove the cover on the bottom rear. Feel the compressor to see if it is warm. If it is, it has been trying to start and could be just the starting relay. If not, the overload could be burned out. BUT with either symptom, the compressor could still be bad. You will need a multimeter to check it for shorted, or open windings. If you are not familiar with these things, please get someone with the expertise to diagnose it.
Dec 30, 2009 | Frigidaire Refrigerators
Please help me, I have a 4 Runner 2003 that has a JBL CD Player and a Cassett player in one built in the dash. Both are not working: The CD Player keeps flashing (Error 3) when ever I put a CD in...
did the error code start with the tape getting stuck? i have heard that if you disconnect the battery for 5-10 minutes it will reset the radio but make sure you have a code for it to unlock it it the radio has security. they say it starts working again if you do this. again this is just what i have heard a toyota tech say when i worked there. it may be that it knows it has a problem with the tape and keeps it inop, as far as getting the tape out, it either breaks the tape or the tape player or both. i worked at a car stereo shop for 10 years and very rare for both to survive.
Oct 28, 2009 | JBL Car Audio & Video
Is is safe to use a cassett car adapter with my i-phone
Sould be fine as long as it is same connection into I phone?.
It is only an audio output and will not damage the I Phone.
You can now get a FM transmitter device that tunes into your FM radio and does the same job.
Apr 24, 2009 | Apple iPhone Smartphone
LG LS-L1210CL Mini Split Air Conditioner Logo
56 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
