Question about Maytag Neptune MAH5500B Front Load Washer
Washer does not hold any water?
The water in my whirlpool washer just goes right through when I start the load. What should I do?
  • 135 Answers
Check that the waste pipe is at least 21" from the floor to prevent this.
Thankyou for using Fixya.
Posted on Feb 16, 2009
What to do about FH error on Whirlpool Duet washer?
unplug the washer to clear the board.turn on the water after one min. plug back in and try again
Sep 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
How to correct control locked will not go off on whirlpool ghw9150 washer
While the machine is 'on' press & hold the "end of cycle" button for 3 seconds, or till the lock light goes off. This is on the far left or right of the machine's panel. Good luck! Pl rate me.
Sep 01, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start
Press & hold down the 'end of cycle' signal button at right end of panel, till the control light goes off, usually 3 seconds. This is the child lock feature. Do it again and it locks.
& rate me pl................4 thumbs
Jan 12, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Just bought a front load whirlpool wash machine. when i turn it on it locks door then unlocks door, it does this 2 to 3 times then the washer fills with some water only spins about 3 times then it waits...
This washer will stop and start a number of times during fill as it is sensing how much water it needs. Also you must hook both water line up and have both on. Also you must use HE soap and very little of it.
Feb 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Thw washer fills with water when off
The inlet valve is faulty and you have to replace it. It is located on the right side of the machine viewed from the rear where the fill hoses are attached to.Turn-off the water supply, unplug the machine and do the following:
  1. Remove the three screws holding the top panel in place.
  2. Disconnect the hoses and electrical connections to the water inlet valve.
  3. Remove the mounting screws holding the water inlet valve.
  4. Reinstall the replacement valve.
  5. Reinstall the hoses and the electrical connections.
Replacement valve part number for Whirlpool Duet GHW9150P front load washer is 906483.
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water goes into the washer even when the washer is off
Yes , the valve is stuck. take top cover off to get to it by removing 3 or 4 screws from top rear and replace.
Phil
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer Completes 1 Cycle then won't fill
Sounds like you have sticking water level switch, due to possible blockage in the pressure chamber or pressure chamber hose..
You need to check the pressure chamber and the small hose that is attached to it for a blockage,. This problem will cause all of the symptoms you have described.. When it is stood for a while that is why it will work, the pressure releases and the switch will work until the pressure builds up and then it sticks again. The pressure chamber hose goes up to the water level switch
Please rate this solution
Dec 15, 2008 | Whirlpool LSR8233J
Whirlpool Washer not going thru cycle
IF YOUR MACINE WONT PUT WATER IN IT WHEN YOU TURN IT ON ITS THE WATER INLET VALVE IN BACK WHERE YOU HOOK UP THE WATER. IF THE WATER GOES IN WHEN YOU TURN IT ON THEN ITS MORE LIKELY TO BE YOUR LID SWITCH. YOU CAN GET EITHER OF THE PARTS AT YOUR LOCAL APPLIANCE DEALER OR EASILY ON LINE. JUST HAVE YOUR MODEL NUMBER HANDY. GLAD TO BE OF SERVICE.
Nov 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
It will not fill with water
how do you open top on whirlpool washer?
Jan 23, 2007 | Whirlpool LSR9434PT Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
79 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
