Question about RIM BlackBerry 7130c Cell Phone
Screen shows battery with a red line through it
Just got new blackberry 7130c and it worked fine when I turned it on for the first time, but now when i put the battery back in the phone turns on by itself and the screen just shows a battery with a red line through it. Thought maybe itwas a bad battery, but i put the battery in another one of my blackberrys, and it works fine
    Problem Solver:
  • 6 Answers
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Posted on Sep 04, 2009
I want to unlock my black brrry
You can use the unlock code to unlock the BLACKBERRY 7130C easily,get the unlock code at here Mobile-unlocker.com
and Unlock it from network lock.
Jan 23, 2012 | RIM BlackBerry 7130c Cell Phone
MY BLACKBERRY BOLD 9000 WON'T TURN ON!!! My friend gave me her Blackberry Bold 9000. It's battery was replaced a few months ago but it hasn't been used since then. When I plug it into the wall charger,...
Ok...don't panic. The charger you are using is not compatible. Verizon only works with verizon blackberry's. Non verizon will not work with blackberry and vice versa. This is what will happen. you plug it in and it will boot for a few seconds and then the lightning bolt you see is the charge icon and then a red line in it means that charger is not compatable. Blackberry does make its own charger but there is a "pin" on the plug in that will tell it it is not the right one. Am I confusing you?
Jan 06, 2011 | RIM BlackBerry Bold 9000 Smartphone
Blackberry 7130c pin number
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Jun 21, 2010 | RIM BlackBerry 7130c Cell Phone
My blackberry pearl has a battery showing with a red line through it. I have charged the battery and put a brand new battery that is charged in it but the same signal keeps showing up.
In this case you need to take out the Battery of your Handheld and check with the other handheld, If it is working fine then there is a problem with your USB cable you need to walk into the service center for this.
Oct 18, 2009 | RIM BlackBerry Pearl 8100
Blackberry Curve 8330 won't turn back on
Pull the battery out and put back in. Then hit the reset button on back panel.
Sep 05, 2009 | AT&T Blackberry Curve 8300 Smartphone
I dropped my blackberry bold and screen is white with red line
That means no battery, your lucky. Just go to a phone place and try a new battery. I am assuming you already took the battery out and tried reinserting it. Does the battery have red xx's on the bottom, if so it probably fell on grass and the moisture got to the battery some how.
Aug 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry curve 8300 suddently died
Try somebody else's battery, if the problem persists, it's most likely a logic board issue. There are blackberry repair websites that show you how to do the replacement yourself, otherwise here is a service that can repair any Blackberry Bold, Storm, Pearl, Curve, 8800 for screen, lenses,
track balls, usb ports, waterdamage etc.
The website is: Blackberry Repair
Jul 27, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 7130C
What you need to do is go to RIM's website find software you need for your phone and download and install it to your computer once there and assuming your phone supports the blackberry desktop software connect your phone to the computer via USB and then run the software and everything should be fine afterwards. :)
Cheers,
Kyle
Jul 10, 2009 | RIM BlackBerry 7130c Cell Phone
RIM BlackBerry 7130c Cell Phone Logo
770 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
