Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Shaking my machine shaking while it spin
  • 360 Answers
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
Nextra is shaking itself to bits and extremely
sounds like the bearing has gone possibly taken out the drum support to shaking could also be one of the wieghts has worked loose.
Mar 15, 2010 | Hoover Nextra HNF 3157 Front Load Washer
Washer will not stop shaking during spin cycles, we have removed akll shipping bolts
Place a load in the machine use a good level to get machine perfectly level. Now put machine on spin and check the feet. Find the one that is not solid and slowly adjust it until it stops shaking. PS place level on flat top surface and level side to side and front to back.
Jan 26, 2010 | LG Washing Machines
Spin cycle problem
I had the same problem you need to pull out your washer and observe which leg is uneven this should be the source of your shaking and if you use the proper tools you can solve this.
Dec 31, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Excessive shaking during spin final cycle
check to see if the floor is solid and not soft, thin or flexible. are the leveling legs tight? make sure the locking nut is tight and that the leg does not wobble.
Dec 23, 2009 | Maytag Washing Machines
Shaking washing machine
If the shaking is during the spin cycle and you are using the High setting change it to Medium. This may fix the problem and the clothes will probably come out even dryer since the drum is not banging around.
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle - washer is shaking and jumping
Try to relevel the unit. Another suggestion is use the cycle for delicates (the spin cycle is slower). If it is still out of balance and shaking one of the dampers may have broke
Aug 17, 2009 | LG WM-2277HW Front Load Washer
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Shaking and Spinning Unevenly
Beneath the front panel you may find screws. To have access to your filter. Check the drain to make sure it isn't clogged, also the drain hose.
Re the shaking, etc you have to check for any dampers (shocks) that have come off or broken, also springs.
Mar 19, 2009 | Frigidaire Affinity ATF8000FS
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
WAY too much shaking
Take out the four "shipping\travel" bolts in the back of the machine. Read the manual- it will tell you how to do this. John
Apr 29, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
150 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
