Question about LG DLG2525S Electric Dryer
LG dryer not working
When I turn the power own the "check filter" light comes on. I can't find my manual and don't know what that means. It is not the lint filter.
  • 360 Answers
If the light comes on when you power up the unit, the filter may not be properly inserted.
You can find a copy of your owners manual --->here<---
please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
Dryer is not heating and it says check filter. What does that mean?
there is a lint filter that needs cleaned . usually every time you use the machine check this link LG D1102W Owner Manual Page 35
Apr 06, 2015 | LG DLG5002W 27" Gas Dryer
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
Check filter light flashing
Whenever you get the check filter light, it means that something in your exhaust air is blocked. It could mean that your lint screen is not passing air through due to an accumulation of lint or a build up of the lint from your fabric sheet or it could mean that the air hose exhaust is clogged.
Hope this helps!
Hal aka ImJustAvg
Dec 29, 2011 | Dryers
I have a signal saying to check the filter. I know where the vent is and the lint collector, but I do not have the book and I don't know where to find the filter.
The flashing filter light is just a reminder to check the filter before running the unit. If the filter screen is clean, then no need to be concerned about it.
Jun 10, 2011 | LG DLE5977 Electric Dryer
My LG dryer says check filter but I've cleaned the wire filter and the lint that was trapped under the filter. It still says check filter. Is there another filter?
I relocated my drier and noticed the same light when I plugged it back in. The owner's manual states that the light comes on whenever the drier is turned on, to remind you to check the one and only lint screen.
Apr 17, 2011 | LG DLE5977 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
What is the icon's mean on the dash board, when climbing on a hill there's a red light on, but going down it turns off. it looks like there's is over heating or something, please help max'd 07
It depends on what warning light is on!
In any case, from your description and experience, it would be your engine 'Oil' warning light: it comes on when there is not enough lubrication (thus the overheating) flowing because of low oil pressure: immediately check your oil leveland top up as required) and make sure that change your oil and oil filter as soon as possible as it is a very damaging condition and the engine could seize.
Hope it helps: let me know hoe you go.
Jan 02, 2010 | 1997 Mitsubishi Montero
Won't heat up
Try removing the lint filter from the dryer and with no clothes, start the the dryer, and if it works then replace your lint filter.
Tip: Fabric softener sheets in the dryer can deposit an invisible coating on the screen of the filter and reduce air flow.
May 27, 2008 | LG DLE2532W Electric Dryer
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Clean lent filter sign shows and won't let it run. power is on and have manually checked the vent hose, exterior exit. still won't work Clean Lint Filter Indicator Light Flashes but my lint filter is...
check for wires near lint filter casing. these are the lint filter sensors, they could be defective that is why it always indicate a clean lint filter alarm,
Feb 19, 2008 | Dryers
LG DLG2525S Electric Dryer Logo
455 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
