Supposed to have limiting volume internally, but can't see that this works. I tried them with my pc and as I increased the volume, the volume went up in the headphones and the full volume seemed to be quite loud. These are the kids h'phones and I was hoping the limit was set for right level.
SOURCE: I need a replacement rubber ear pad for one of my headphones.
most best buy stores have extra axcessories where the headphones and portable tape players are. try there, they might have them.
SOURCE: i can only hear in one side of the headphones
Make sure the plug is fully seated in the playback device. Try plugging the headphones in a friend's .mp3 player. If the problem persists, your headphones are probably bad and will need to be replaced.
SOURCE: My JVC stereo headphone's wire is broken, cant i
If you take off the covering to reveal the speaker you can solder the connection back onto the left side of the headphones and that will fix it.
SOURCE: The headphones have stopped working
Andrewjdonne,
This is usually caused by a short in a wire. If you are brave, you can open up the headphones and find the wire that has shorted out and repair it. Usually this happens at the point where the headphones pivot. This may require the use of a soldering gun, or at least some new wire and electrical tape. Nothing you can't find at radioshack. Let me know if you need help opening the casing up to find the bad connection!
~Kudos~
