Question about Miele H378B2 KAT Electric Double Oven
How do i remove a built in oven?
My oven has broken and decided to buy new one
however i have to remove oven from casing before new one can be fitted it,s a miele double oven
  • Anonymous Mar 29, 2014
    Immovable light housing (top fitted) in Miele oven
I need audio driver intel D945gcnl
Posted on Feb 16, 2009
Will a GE built in oven JT3000DF fit in the space that has a Kenmoore build oven in that space at this time 9114105559 part number
Simple. Measurements. Unless i'm missing something here.
Take present oven detailed measurement, compare it to the newer oven's detailed measurement.
Feb 03, 2015 | GE 30" Built-In Single Electric Wall Oven...
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
I have an electrolux double oven eou 6330 the bottom oven element has broken.Can I buy and fit it myself as single female with very little spare cash?
Yes. You can do it. Part should be $40 or less.
Turn off the power to the oven. Remove the oven racks.Unscrew the element screws from the back wall of the oven. Carefully pull the element out. The wires may be short. Remove the wires from the element. Do not let the wires pull back into the oven cavity. Take the element to the appliance parts store and have them match it to the existing element. Attach the wires to the new element,insert the terminals into the opening,replace the mounting screws. Turn on the oven and bake away.
P.S. Your model number is not correct.
Nov 05, 2009 | Electrolux EOU6330 Electric Double Oven
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Electric fan kicks in but no heat
hi,
If the fan in the back of the oven is going round and the temperature light is on, but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available on Ebay.
To gain access to the element you will have to remove the backplate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. If your fan oven is getting warm but takes a very long time to cook anything, then you need to check if your oven fan is working. As the element is heating but the fan is not blowing the heat into the oven. To replace the oven fan motor is a little more expensive and a bit more involved.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Electrolux Ovens
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Replacement for built in oven/microwave
Hello tippett_631
Welcome to fixya,
You said, ,
22 years ago you built the house you are currently living in. The above oven/microwave oven was built in. You are interested in replacing this unit with a new unit but it must be the same size. ? by the way i You would be happy with a double oven versus the microwave/oven duo. You have measured across the front of the unit and it only measures 26" across. Any assistance you could give us would be greatly appreciated.
I can help you!
The front is 26 inches.
And how high is it from the top to bottom?
Also when I sell a wall oven I always send out the installer to check the hole or cutout size.
Most of the time no wall oven fits with out at least one cut!
Do you have any room to cut a little on all sides?
What is your model number now. And what color do you want now??
I will send you some GE wall oven models and sizes so you can check your self if it will fit. usually they have to cut at least one side to fit it in the old hole!
Sep 25, 2008 | GE Ovens
Miele H378B2 KAT Electric Double Oven Logo
572 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
