Question about Haier HSB03 Compact Refrigerator
Change the door opening from left to right. Can it be done?
My wife is in a wheel chair and I built her a sitdown kitchen. She needs the refrigerator door to open from the right side and this one opens from the left side. Can it be changed to open from the right side?
  • 360 Answers
According to the owners manual for the HSB03, there are no instructions for reversing the door, therefore it is not reversible as by the companies instructions. I would not recommend reversing the door, even if it appears as though it could be done. There may be vital components within the unit that are not visible from the outside that could be damaged by the hinge screws in the wrong place.
This is the Haier web site if you need it. http://www.haier.com/index.htm
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
    Genius:
  • 1,075 Answers
On most refrigertators this is possable;take a look at the opposate side you should be able to see the holes already in place they might have little plastic covers in them remove and keep.if this is the case its not a big job compared to the kitchen job you done.simply remove the door and move the hinges to the oppisate side, the only thing that would consern me would be the handle position if there is one some doors open by pulling the door from the bottom if this is the case it might not be problem but check the hinges first if the opposite side has indeed holes in place i dont see a problem if you fitted a kitchen im sure a small matter of a handle will not stop you.hope this helps.adrian
How do I replace the broken cable on a 99 Caravan right sliding power door?
Go to a mobility shop that services modified vans to get that done.
Jul 09, 2014 | 1999 Dodge Caravan
The right wheel seems not to be working smoothly. When I try to drive straight it veers to the right slightly, like the left wheel has more more. It is also hard for the chair to turn left because the...
Hi Jack
Sounds Like all you need is for a technition to program you chair. They can do an adjustment to compensate the different strengths of each motor and make the chair run straight Also to improve the turning speed adjustments. Programer is a P&G PP1
Good Luck
mimobility
Apr 26, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Features list reversible door swing. Can this be done on site or does it need to be done at the factory? We are being charged for a second delivery because the fridge came with the dorr swinging the wrong...
This should be able to be done on site. If you look at the top of the fridge, on the opposite corner from where your hinge is currently located, you should see some sort of plug(s) that covers the screw holes that are used for changing the hinge between left and right. The same thing on the bottom face of the fridge body. You will see the screw holes to change the bottom hinge side as well. The doors themselves should also have plugs that cover where they sit on the hinges when the door opening direction is changed. I've not done it with model of fridge before, but I have with many others (installed them for a living when I was younger) and it should be a very simple DIY job providing there aren't any water tubes for the ice maker going into the door. Even then, with a bit of patience you should be able to do it rather than be charged for such a simple thing.
Hope this helps!
Jun 25, 2010 | Amana ABL2222FES Stainless Steel Bottom...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Jul 01, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Jan 11, 2009 | Pride Go Chair Travel Power Chair
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Haier HSB03 Compact Refrigerator Logo
654 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
