Question about Nokia N75
It doesn't start and the battery is fully charged. Light comes on though
  • Anonymous Mar 28, 2009
    Fully charged and phone won't turn on. The phone or battery isnt a year old and had not been damaged by me.
  • Anonymous May 12, 2009
    a mi me paso igual le puse un tema y el reproductor no me funcionaba y cuando lo apague y lo encendi me mandaba un mensaje "erroe de encendido" y no lo he podido encender. y no es la bateria, ni la memoria SD.
Yo tengo el mismo problema y no es la bateria, ami me manda un menasaje "error de encendido" y desde entonces no enciende y ya intente de todo.
Posted on May 12, 2009
    Guru:
  • 832 Answers
Hello there! thanks for using Fixya.com!
Please try to use other battery. Let us see if its still the problem. If the same problem occurs, better you check with your technician so that he inspect further the circuits or your LCD screen.
Posted on Feb 16, 2009
My battery light keeps coming on even though my mechanic said there's nothing wrong with it.
If you're certain the battery is fully charged, then you need to check your serpentine belt out for bad teeth which will cause it to slip, then your alternator with a multimeter to see if it's charging the battery.
A simple method to see if the alternator is working at all is to start the car, then remove the negative battery terminal. If the car dies immediately, the alternator isn't charging.
This should help you isolate your problem.
Mar 24, 2015 | 1999 Pontiac Sunfire
Vec010s
Most likely that is the issue.
May 17, 2013 | JUMP START SYSTEM
Car won't start. it tries to turn over, but just doesn't .battery replaced several months ago so it's not that. The red "GEN" light pops up. Is that the generator signal? Manual doesn&
Interesting. They haven't used generators in over 50 yrs.
But yes that was the warning light for the generator.
If you have a volt meter that would tell you what the system is doing.
If the engine will not crank, and the battery is fully charged, you would need to check the connections at the starter for voltage and ground.
And the red warning lights would normally come on until the engine starts.
Jan 13, 2013 | 1996 Jeep Cherokee Sport
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
My sp will not charge, I am not sure if it is the battery or something else
Game Boy Advance SP - Charging Light Won't Display If the orange-colored charge light on your Game Boy Advance SP is no longer coming on when the A/C Adapter is connected to your system, please use the following troubleshooting steps.
    Troubleshooting Steps:
    1. Make Sure the Game Boy Advance SP Isn't Already Fully Charged
      If the battery is already fully charged, the light will not display when the system is plugged into the AC Adapter. Play a game without using the AC Adapter for at least 10-15 minutes, then plug the AC Adapter in, to see if the light comes on. If it does come on, the battery was fully charged. If the light still does not come on, see Step 2.
    2. Make Sure the Outlet You Are Using Works
      Plugging another electrical device into the outlet is a good way to check if the outlet works, or that the outlet you are using is not controlled by a nearby light switch. You may also want to try a different outlet.
    3. Try a Different Licensed AC Adapter
      If the charging light doesn't display, try a different AC Adapter, if possible, to determine if perhaps the problem is with the adapter.
      • If a different AC Adapter works, you will need to get a replacement AC Adapter from our Online Store, or by calling our Consumer Service Department at 1-800-255-3700.
      • If a different AC Adapter doesn't work, or if a replacement AC Adapter is not available and the lights will not display, we recommend having your Game Boy Advance SP repaired. Check out our convenient repair options.
    Note: Please be sure to include both the Game Boy Advance SP and the AC Adapter with any repair
Sep 02, 2011 | Nintendo Game Boy Advance SP Console
Msi u100 shuts down when power cord is removed. battery is fully charged. blue light on panel not coming on.
Sounds like a faulty battery. It's saying it's charged but obviously isn't. Best to check the battery contacts are clean first though obviously, otherwise try another battery.
Mar 01, 2010 | MSI Microstar U100053LA Notebook
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
Nokia N75 Logo
270 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
