Question about RCA RP-7987 Boombox
On and Off Button
The on and off button is broken on my radio, i need to get a replacement on and off button for it.
Where should i get this part?
Don't want to buy another radio to replace this one, just need the part.
Model no.-RCA RP-7987 BOOMBOX
Write back ASAP!
  • 4,234 Answers
The part number for this is: 43A24856
Unfortunately, this part is no longer available from RCA parts distributors. Check service shops in your area for parts that they may have in stock.
Dan
Posted on Feb 17, 2009
Can I replace the PTT button on the radio from a housing kit?
Why not just do the whole housing? It is often easier than you think and easier than removing one little part that is likely to get broken.
Brand and model of radio would help a lot.
Sep 01, 2015 | Radio Communications
PTT button on RDV 2020 is hard to push
This problem is typically caused by small component behind the PTT button being cracked or broken. The RDX series radios respond best if the user presses the PTT button in the center versus the top or bottom sections of the button. Once the button becomes hard to press it is best to get the radio repaired. Commonly if the radio remains in use the PTT issue will get worse as the internal PTT component is pressed harder, pushing it further away from the outside button and eventually loosening it from the component board.
Best regards.
Apr 18, 2014 | Motorola RDV2020 Two Way Radio2 VHF 5...
1995 Lincoln Mark VIII radio on/off button sometimes pops up
the spring loaded retention clip is probbably broken in the radio...toothpick.quick fix... replacement....expensive fix!
Apr 10, 2013 | 1995 Lincoln Mark VIII
How to eject with radio shack 3 in one universal remote?
Try an other code. some codes might work with all function buttons.
May 30, 2012 | Universal Remote Control Televison & Video
Rewind button on Coby broken - how to replace
nesecito el picki-up laser lens para un boombox coby modelo mpcd 450blk hern7869@gmail.com
May 22, 2012 | COBY-PERSONAL & PORTABLE Coby Mpcd450...
We have two radios with problems, one the volume is to low and wont respond to vol control and the other has a problem with the transmit button,sometimes it works fine other times not
On the radio with the low volume, it is possible you are having a low receive (Rx) issue, or you have a bad volume potentiometer. It would need to be seen by a radio technician to determine the exact cause and if it can be repaired. In most cases, the flat rate repair for this style of radio is around $69 ea.
Your second radio with the transmit button (PTT) issue likely has a failing push-to-talk internal button, or a broken spacer behind the rubber plug. These would be common failure parts on this type of radio and replaced during a repair.
Best regards.
May 10, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
BMW radio on/off button broken
There are radio restoration companies that will do the same thing for you from $100-$300 but you will need to remove and send the radio to them unless you can find one near where you live. Aftermarket replacement will be easier and less costly. Sound Authority is a good place for an aftermarket replacement if you do not have them close by. Check out the store you plan to use, some stores will not do installations for BMW, Mercedes, Jaguar, etc.
Jul 10, 2009 | 2003 BMW 325
Can't release tape from CTR-121
How much warranty you have left on that product. It sounds as if you need to get that replaced. Or You need a new button. something may be broken off inside the machine.
Dec 12, 2007 | Radio Shack CTR-121
393 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
