Question about RCA Televison & Video
Rca d52w23 convergence problem error code 84
What does error code 84 mean I have the same problem with my 52" RCA (D52W26)
the screen has a bow to it
service menu has no convergence settings either
been looking at all these peoples postsand getting confused
one person says i have to r&r resistors and heat syncs
someone else says it may be as easy as changing fuses
and i havent seen a board on here like mine
if someone could help would be much appreciated
  • 1 more comment
  • walter_m Feb 16, 2009
    I found the fuse it didn't show any continuity
    is this all i have to replace ?
  • walter_m Apr 10, 2009
    I finally got the fuse and installed it convergence problem fixed thank you very much. now everytime I turn on the tv it sets up the convergence is there a fix for this?
  • walter_m Apr 11, 2009
    are you willing to share............
  • RCA Master
  • 5,138 Answers
Go to menu then setup does it have convergence on menu if not then you have a open fuse FL231 it will be the middle fuse there will be 3 of them on right side of FBT flyback transfomer.let me know!
Posted on Feb 16, 2009
  • 1 more comment
  • ladywinn
    ladywinn Feb 16, 2009
    Yes, this is a Fixya answer. BINGO!
  • ladywinn
    ladywinn Apr 11, 2009
    YES there is.
  • ladywinn
    ladywinn Apr 14, 2009
    IN ORDER to fix this you must Enter Service Mode.Type in your make and model then look up How to enter service mode.This should be posted under solutions here!
HDTV monitor 52 in. Model #: D52W26 Serial #: G072CU07E colors are separated, warped screen and cannot find auto convergence
Very easy repair. The ITC222 and ITC222A convergence option missing repair kit available from www.tvrepairworld.com will solve that issue. Its listed under the RCA repair kits and has the parts and the CD with repir instructions.
Mar 31, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA D52W23 has 3 colors split.
Thats a convergence failure. You can get a repair kit called " The ITC222 and ITC222A convergence option missing repair kit" From www.tvrepairworld.com which should solve the issue. The kit also contains the CD with instructions.
Apr 02, 2010 | RCA D52W23 52" HDTV CRT TV
Bowed Picture; Still have access to convergence. HELP!
The convergence power supply board is usually the cause of that problem. You can get the replacement Convergence power supply board from www.tvrepairworld.com
Apr 01, 2010 | RCA D52W23 52" HDTV CRT TV
My RCA 52 inch projection tv looks 3d. I can't find the setting to fix the screen. The mod number is d52w23
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 27, 2010 | RCA D52W23 52" HDTV CRT TV
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 52in HDTV red and green ghost and bowing lines
Ur convergence it dead,need convergence kit,use what in that kit,U know to solder? Tries websites Tv Repair World.com,Ebay.com
Oct 06, 2009 | RCA D52W23 52" HDTV CRT TV
Convergence problem
Did you replace the convergence power supply board, or the Convergence board?
Sep 23, 2009 | RCA D52W23 52" HDTV CRT TV
consult the fl231 problem in tips and tricks section
Dec 15, 2008 | RCA P52960 52" Rear Projection Television
D52W26 Convergence board
Yes the D52W20 and the D52w26 are both ITC222 chassis they are exactly the same
Jul 17, 2008 | RCA P52926 52" Rear Projection Television
Convergence amp or board???
Go to this site and leave them an email indicating the model number of your set and the symptoms your having they will be able to help you out with the problem.
http://servicemanuals.vstore.ca/
May 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
508 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
