Question about HP L1706 17" LCD Monitor
Shadowing of text
My monitor now displays a faint shadowing behind all of the text and images on the screen which makes it really tiring to read and use. I have had the monitor for 18months and this has happened in the last 2 weeks. Any ideas? Thanks in advance for your help.
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
This may help...SIMPLE ! The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I moved the cables apart, and no more shadows !! Sounds too easy, but it works. Takes a few seconds. Immediate results.
Posted on Oct 09, 2014
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from
Posted on Feb 16, 2009
My 2 year old Syncmaster 740N often has multiple faint images behind text in any program and multiple faint desktop icons making it look "smeared"; some days worse than others; resolution is correct at...
Well in monitor you can do one thing - disconnect the monitor cable*(VGA Cable) from the tower and chk still if u have the same faint screen that means monitor gone bad if not than uninstall the Grapics Driver and shut down computer... if u have internet than restart and go to device manager ( Run - devmgmt.msc) under display adapter right click on grapics name and update driver.
Oct 14, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Samsung 931B monitor - shadowing
I have the same monitor, and twice I've experienced this exact problem. In my case, the video connectors have relaxed. If I wiggle the cable, I can make it better or worse, so it's time to disconnect, reseat. I don't know if it will work for you, but it's free!
Feb 20, 2009 | Samsung 931BF 17" LCD Monitor
Double Images / Shadows on the monitor screen
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Has a shadowing problem where everything on the screen was shadowing to the right. Did basic troubleshooting techniques and found that it was due to a loose connection to the computer. You may want to check this if resetting to factory settings doesn't help.
Apr 18, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Samsung monitor has "streaks"
LaurieEm posted a solution which seems to work for me (in addition to some other stuff, read my problem description) for this here
Try re-plugging your LCD monitor's VGA connection. It may be a case of corrosion on the pins or bad puggin of the cable. The problem is also reduced by using compressed air to blow out the cicuitry in the back of the monitor to remove dust. Both of these seem to work, and if you can't solve the problem totally with one, try the other one as well.
Mar 06, 2008 | Samsung 931BF 17" LCD Monitor
Shadows and Ghosts on the Screen
Plugged up display via the VGA cable to an HP dv6000 laptop; the Acer powered up and displayed fine ... however, noticed a faint waving motion in the picture, as if the screen was literally gel and began to wave, from top to bottom as it appeared. Best I can describe it ... any suggestions as to why? I only connected it to this HP to try it out, I ordered it from newegg and wanted to make sure pixels werent dead on arival. I will be getting an Aurora 7500 (Alienware): AMD X2 6000, Windows Vista Premium, 2GB RAM, GeForce 512 8800GT, SLI ready motherboard ... I heard good things of Acer and hoped this display would look great with my soon-to-come setup and im sure it will. However, just nervous it will do this on my Aurora. Any help or suggestions would be beyond appreciated!!
Feb 19, 2008 | Samsung SyncMaster 191T 19" Flat Panel LCD...
HP L1706 17" LCD Monitor Logo
448 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
