Question about IBM ThinkPad R31 2656 Notebook
What are the steps and files to activate F11 recovery system????
I just want to know how to make the F11 recovery system active.
So, i no need to waste my time to recovery my pc or laptop.
And what are the files required to put inside the safe zone.......
Pls help me....
Thanks
    Master:
  • 474 Answers
Typically your XP system has a restore for settings which is a program in windows.
F11 on boot is a type of recovery that bassically recovers your windows unless it specifies otherwise or is part of the system Bios.
It usually recovers from your install disk and restores your windows and leaves the personal files intact. This is if you accidently damage some windows files through tinkering and what not. Relying on the laptop as a back up is not a good idea because everything is on one Hard drive and if that goes, then your stuck.
Your better off getting an External Hard drive and connecting it, backing up all your personal files to it, and then leaving it stored in a safe place in case something bad happens.
There is also a way to use the windows CD to restore the windows files from the Windows installer when booting from CD which restores all the OS files and leave the personal files intact. Allthoug it does reset all the windwos prefferences.
As for ths F11, I have that option as well and fine it not to be reliable.
Hope this helps point you in the right direction.
Posted on Feb 16, 2009
Please send me a step by step procedure on how to reformat my HP cnCompaq6220.
F11 is the key to press or
1.Right-click on "Computer" icon and select manage.
2.This will launch the Microsoft Management Console.
3.On the left side of the MMC, click on "Disk Management" and it will show you all of the partitions.
4.Right-click on the "HP Recovery" partition and select "Mark as Active Partition."
5.When the warning prompt appears, select "Yes" - Reboot and it will automatically boot into the Recovery Manager (without pressing F11).
Sep 26, 2015 | HP Computers & Internet
Missing Operating System on D: partition Bootup
Follow the steps from this site http://www.wikihow.com/Change-the-Active-Partition-of-Your-Hard-Disk-with-Parted-Magic. When you changed the active partition you told the computer to look for information from the wrong partition. Using the program from that site will allow you to make the other partition active again. You'll then be able to boot into Windows again. As far as making backup discs, I believe you hit F11 while booting to access the recovery partition. From there you can make your recovery discs. Not 100 percent sure on that though. And you will need to get the windows partition set back as active first.
Jun 19, 2013 | HP ProBook 4510s FM849UT Notebook
Bootmgr missing on hp pavilion slimline s5503w
This document pertains to HP and Compaq desktop PCs that came with Windows 7.The following error opens when attempting to start the PC:BOOTMGR is missingPress CTRL+ALT+DEL to restart the PCIf you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
  1. Open HP System Recovery:caution.pngCAUTION:Do not perform a system recovery! Stop at the first recovery screen.
    • Press the F11 key repeatedly while the computer is starting.
    • If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
  2. Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
  3. If the error message persists, open the recovery manager screen as was done in step 1.
  4. At the recovery manager screen, press ALT + D.
  5. Enter the following text at the command prompt: bootrec /rebuildbcd
  6. If bootrec displays "Add installation to boot list?", press y .After bootrec completes successfully, the computer displays "The operation completed successfully".
  7. To close the command prompt, enter the following text: exit
  8. At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
  9. The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Feb 10, 2012 | HEWLETT-PACKARD Pavilion Slimline s5503w...
Hi, hmm my external drive when i pllug it in no longer connects when ever i try to connect it to my computer. Is there anyway i can recover back all my files within my external drive ? Some people have...
I believe that the demo will only recover 54kb because it only a demo.after that it may ask you to purchase the real active file recovery software.
if in doubt it would be a good idea to take down to a IT specialist and get done properly.A few dollars is worth spending on the recovery of lost Data,aye??
G.
May 29, 2011 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Hi, I accidentaly deleted my favourite music file. How can I restore it?
There is a chance it can be found in your recycle bin. Other than that, here is a link to a utility you can download which should restore the file for you.
http://www.softperfect.com/products/filerecovery/
Please let us know if you get your file back. Thank you.
Sep 16, 2009 | Intel Motherboard
My system won't boot because the windows\system32\config\system
If i am from Singnet technical Helpdesk, we are advised to direct you to Acer Service centre if you owned an Acer computer with a serial number and if it is still under the warranty period on Operating system missing, Another option is to contact Microsoft service centre for CD replacement or oprating system advise since they are the suppliers and vendors for fathering the operating system, To troubleshoot your missing files,you need to know pecifically which files are missing and are they registered in your O/S and are they active and running or are they deactivated, takes longer time to solve missing files problems because you did not list what files are missing and you need to tell microsoft what files are missing in our operating system as there are thousand of files in the WIndows operating system
Jul 23, 2009 | Acer Aspire One AOA150-1983 Notebook PC
Want to reset to Factory Default
with HP the recovery console activation should just be F11 without the CTRL.
If your recovery partition does not work, or is corrupt/missing then your best bet is to either order the recovery discs or take it to a local tech that may have access to OEM discs that can be used with the license key on the machine to reinstall the operating system.
May 01, 2009 | HP Pavilion 523n (P9851AR#ABA) PC Desktop
Operating system
well sir i seeemsthat u have corrupted the operating system if that is the case what u can do is u can get the operating system back without the recovery cd.. from the d: drive partion that is shipped with the system.....so if u r using xp then u can recover the computer back to the factory settings by tapping F10 and if it is vista and keep tapping F11......when u do so it will take u to the partion if u r in xp
for xp recovery foloow this step:
select run system recovery....
then select advanced option...
select distructive recovery.......
select recover without backing up......it will restore it back to the faactory settings...
but if it is vista then follow the following steps :
tapp F11...
it will say welcome to recovery manager.....
clcik on advanced option.....
and then click on the option that says system recovery...
select next.......
select recover without backing ip and it will do it and resetup the computer as u did when u first took it out of the box
Apr 11, 2008 | HP Compaq Presario R4000 Notebook
E Drive
hi my dear friend
don't worry
search download this software and recover your e drive and all your files
software is "active partition recovery and active file recovery for recovering of your files"
Mar 16, 2008 | Microsoft Windows Vista Ultimate Edition
IBM ThinkPad R31 2656 Notebook Logo
226 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
