Question about Dewalt DC927KL Heavy Duty 18 Volt Cordless Hammerdrill
Removing the dewalt DC925 'rohm' chuck
How do you remove the DeWalt DC925 chuck? This is the new drill (not DC988) with the Rohm chuck and it doesn't apear to have a retaining screw on the inside.
Many thanks I want to remove the Rohm self tightening chuck from my new DeWalt DC927 18v lithium ion drill. But it does not have a retaining screw inside. Any ideas out there?
  • Anonymous Mar 21, 2014
    The drills transmission needs to be reassembled.
    Problem Solver:
  • 8 Answers
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
Posted on Dec 10, 2009
  • 2,176 Answers
I checked on both the models listed and apparently they don't want the user to remove. They have a special service fixture for chuck removal that lists for 72.74. I would suggest that you might take it to a authorized center or service center and ask them to do it. BUT keep in mind that you need a chuck identical in the mounting to replace it. Let me know the outcome I would be interested, Thanks
Posted on Feb 16, 2009
Removing chuck from dewalt dcd925
open chuck and look in the bottom of it (chuck)there is probably a screw there. think it will be left hand thread
Oct 25, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do i change the chuck on my dc925
under my handle for this site, go to the tip section and I have detailed instructions on how to remove this chuck. Let me know if you need more assistance.
Apr 19, 2011 | Dewalt DC925 Cordless Drill
How can i remove the chuck from my cordless dewalt power drill
Hello, W/D here.
To remove your chuck, open the jaws of the chuck fully, but don't open them so tight that they lock in the open position. Remove the screw inside the chuck. Spray the inside of the chuck with penetrating oil. Tap around the edge of the chuck, while pulling it away from the motor.
It should come right off, with a little effort.
Best regards, --W/D--
Feb 08, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Need repair schematics for dc988 dewalt cordless drill
web search-dewalt dc988 schematics-click on 2nd site,{parts list and diagrams
Oct 06, 2010 | Dewalt 18 Volt Dc988 Hammer Drill,dc825...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
I have a dewalt dc925 combi drill the chuck keep slipping and also the setting ring is hard to adjust . What can i do top solve this?
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part $of the drill. Then pull it apart. The transmission comes in a one piece cassette. Insert it, and put the front back on and tighten the screws.
Mar 10, 2009 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
I simply placed the chuck into a large vise and turned the drill counter clockwise and the chuck spun right off no problem without damaging anything!! It does have some thread lock on the chuck but just use your man strength and its as simple as turning the lid off the pickle jar! Do not waste your time or money with the removal tool...YOU DONT NEED IT!
Nov 24, 2008 | Dewalt 18 Volt Compact Drill Kit
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
Keyless chuck problem
I had the locking screw come loose in the center and bottom of the chuck it has a left hand thread and is a torx head . It had backed out and prevented the chuck from closing.
Mar 14, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC927KL Heavy Duty 18 Volt Cordless Hammerdrill Logo
3,105 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
