Retail Supplies Logo
Anonymous Posted on Feb 21, 2013
Can you do metal detecting under water? - Retail Supplies
Jennifer Green
Level 2:
Habit-Forming:
New Friend:
  • Expert 33 Answers
  • Posted on Apr 18, 2018
Jennifer Green
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
33
Questions
11
Helped
9068
Points
195
Shawn Hudson
Level 2:
Sergeant:
  • Retail Supplies Expert 190 Answers
  • Posted on Jan 11, 2018
Shawn Hudson
Level 2:
Sergeant:
Answers
190
Questions
44
Helped
72302
Points
980
Taking the time to select the best type of under water metal detector is important. If you will be hunting in salt water, a Pulse Induction will be your best choice. However, if you do decide on a VLF underwater metal detector, be sure that it has a salt water mode. Bounty Hunter VLF Metal Detector Review Detectorly
Anonymous
Level 1:
New Friend:
  • Contributor 53 Answers
  • Posted on Feb 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
53
Questions
40
Helped
21429
Points
64
Yes, metal detecting under water is actually quite popular. There are a few types; Snorkeling with a metal detector, Scuba detecting and Shipwreck diving.
All of these types require equipment that can be expensive to hire/ buy.
2answers
What metals do not set off a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Elenco Metal Detector With Beep Alert Review Detectorly
2answers
What metals can be detected by a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Best Underwater Metal Detector In depth Guide Reviews For 2018
2answers
Do metal detectors detect all guns?
no
it cannot detect plastic guns or 3d made guns unless the bullet is in the gun
It is called a "metal " detector
2answers
What is the hobby of metal detecting called?
A metal detector is an electronic instrument which detects the presence of metal nearby. Metal detectors are useful for finding metal inclusions hidden within objects, or metal objects buried underground. They often consist of a handheld unit with a sensor probe which can be swept over the ground or other objects. https://detectorly.com/complete-guide-metal-detecting
Mar 18, 2018 • The Toys
After every wash I have to center the basket or it will cause leaking while filling up with water for the next wash. Why won't the basket stay centered. This has never happened before. Thanks
Hum sounds like a bad thrust washer on the agitator spindle but that should not effect water overflow? may be wrong and it could be a bad water pressure switch, if it does not detect water level it can allow an overfill? check with a multi meter for continuity. if u mean the basket is leaning in 1 direction to low then u may have bad balance counter weights or the metal has corroded and the drum cannot be held firmly when under pressure.
3answers
Need a manual for a gold digger gc-1019
You can get a downloadable manual for all Bounty Hunter,Garrett and many other brands of metal detectors at www.Shopmetaldetectors.com
ENGINE COOLANT LEAK FROM BACK OF ENGINE WHERE IS THE WATER PUMP LOCATED
Hopefully just a water hose or connection leak...some parts of these hoses are now metal, and rust away...these factory metal hoses are dealer, and salvage yard only...Many times you can replace the entire metal line with a rubber line...as long as you can connect to both sides...there is a water hose that runs under the coolant overflow, to the firewall...(many times the culprit)...the water pump on your motor is under a pulley located on the front of your engine...Hope this helps.
We set up our pool filled it and turned on pump for 24 hours then turned on the saltwater system. Immediately tested the copper level with the strip it said 0 so we put system into boost mode and now this...
Metal in the water. When you fill your pool, immediately treat as if you had metal, according to package insructions ... (pump running generally speaking).
I dont know why, it seems metal is sometimes hard to detect ... treat the water anyway. In my area, the stuff costs less than $20.00 which is way cheaper than removing the metal AFTER you find it!
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
