Question about Brother XL-2230 Mechanical Sewing Machine
Brother XL2230 Elastic Overlock function not working properly
I just bought a new XL2230 and I followed the manual on how to sew overlock stitch but no matter how many times I tried on different material I still cannot get the same result as the picture on the manual shows, in fact it's very uneven, and very stretching.... I returned and exchanged for another new machine but still have that issue. Anyone has the same problems and any tips /advice on this?
I also have the same uneven tension on front and bottom stitch like other ppl have, it's very frustrating.
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Posted on Apr 20, 2009
I am trying to teach myself to sew.... what is a serge stitch an how do I set my brother sewing machine to do it?
A serger (overlocker) is not a sewing machine. If you look at the inside seams of a purchased t-shirt, you will usually find a serge stitch that was created using a serger (overlocker). A serger/overlocker usually uses 3 or 4 threads to create that stitch. It also trims the fabric at the same time it finishes the fabric edge. The serge stitch is a chain stitch that, if you pull a particular thread, the entire stitch will come undone.
Your sewing machine is not able to create that same stitch. Your sewing machine may have what is called an "overlock" stitch, but it will use only 2 threads (the top and bobbin) to create that stitch. You would have to consult your owner's manual to see if it can make an overlock stitch.
Different Serger Stitches and How to Use Them
The BERNINA Serger Overlocker line BERNINA
May 05, 2017 | Brother Sewing Machines
Does this machine have an overlock/serger function?
Page 10 of this manual shows several overlock-type stitches:
www.hammerwall.com/Download_Manual/70204/pj58
Enter the letters/numbers in the box and click "submit query" to download the manual.
Mar 11, 2014 | White Sewing 2235 ETS Mechanical Sewing...
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
It will not do an overlock it will cut the fabric nothing else I followed the directions on how to thread it but the only thing it will do is cut the fabric what am i doing wrong
for all Sewing machines to stitch the cloth, Top needles and bottom hemming needles timing should be configured. Please let us know the whether it is double needle / single needle overlock machine. and model number of the Machine.So that i can guide much better.
Apr 06, 2011 | Brother Sewing Machines
Does the Brother XL-5340 do an overlock stitch? If it does do I need to change the foot and to which foot? Thanks
There is an overedge stitch (page 38) that uses the regular presser foot.
If you do not have a manual, you can download (free) from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=XL5340
Mar 31, 2010 | Brother XL-5340 Mechanical Sewing Machine
Pfaff 1222's 3 stretch stitches sew wrong and backwards only.
It sounds like the feed mechanism needs oil.
Feb 24, 2010 | Sewing Machines
Whats the differance between a overlocker and a sewing machine? I am new to sewing and want to know with to purchases, iv no idea where to start or what to buy?
A overlock machine helps you clean finish the seams. You can do many things with a overlock It can cut your sewing time down. The sewing machine is good for many thing too,Mostly the construction of the garment. I have three machines. A indstrialstraight stitch, a home machine and a overlock.Al for different tasks.
Aug 05, 2009 | Juki MO-644D Mechanical Sewing Machine
Brother XL-2230 Mechanical Sewing Machine Logo
269 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
