Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulan Wild Thing and Wood Shark Saws try to run, but stall down.
Both saws have run well for years. Started to have carb problems with both. Rebuilt carbs on both saws, would run ok for awhile. Replaced fuel lines, new plugs never got any better. Purchased a new carb for both saws, thought they just had worn out carbs. With a new carb the Wild Thing run good for a few days. Now with a new carb they will both crank and try to run, but act like they are sucking air or have a crack in the case. Have the Wood Shark took a part, have not found anything. Cold they be sucking air at the base gaskets or at the bearings? Are they a rebuild kit? Would it cost more than the saws are worth?
Darrell
    President:
  • 1,902 Answers
They could be sucking gas from the base gasket, head gasket or the bearings. Also, Check your flywheel very wheel and your armuter, if either are rusty then they need some sand paper to help create spark. There are rebuild kits and they are cheap. I always tell my customers to fix there older machines cause the new ones are **** and they leak everywhere and if anything brakes they are REALLY expensive to repair. You can get a rebuild kit whole machine for about 65 dollars
Posted on Feb 16, 2009
Poulan Pro Wild Thing will only run with choke out. Carb has been fully rebuilt and new lines added. As soon as throttle is pulled and choke pops off, engine dies. Any recommendations/suggestions? Thanks,...
If not already done replace the fuel filter in the tank, it is obviously fuel starvation, if no better increase the the fuel mixture on the H and L screws ( turn anti clockwise 1/4 turn on each to start with)
Feb 27, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My poulan wild thing will start but will not stay running without holding the throttle. What should I do?
Get some sta-bil fuel stabilizer. add twice the amount recommended on the bottle for storage to your mixed gas. Empty out chainsaw tank and refill with the new mix. Rub for 2 minutes, then shut off. Remove cover over carb and spray inside carb, soaking it down good and cleaning all internal surfaces visible - allow to sit overnight.
Next day
Spray down carb with carb cleaner for about 15 seconds. Start saw, allowing 2 minutes to warm up and reduce choke. If saw stalls, restart and spray inside carb as it runs with choke on - keep motor at the highest rpms you can as you spray - spray in 2 second bursts, not allowing motor to stall from spray. If it stalls, change sparkplug and try again. You have varnish build up in the carb and are trying to remove it so the carb will work without the choke. This may take some time but it is the exact procedure I used for my Poulan Team Realtree last spring - I spent about an hour spraying and staring before it ran without the choke.
Good luck!!
Nov 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 18" Gas chain saw starts no problem but it runs for maybe 30 sec. then stops each time. I changed the core same thing.
Do a tune up. It is easy. Just take out the carb and clean with any commercial carb cleaner nad change the spark plug.
Oct 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
McCulloch chain saw wont stay running after it warms up. I go to cut wood it start to bog down if i let go of the button it idles fine
Is the chain brake engaged? The brake lever should be in the back position. Toward the handle.
was this helpful?
yes
no
Mar 23, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
Feb 03, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Wild Thing-(18")hard starting
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
552 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
