Question about Boss AUDIO SYSTEMS BV9455 Car DVD Player
Buzzing noise I hooked my double din deck with a screen up correctly but there is a buzzing sound when the key is in the on position, but everything else works, does anybody know what can be wrong.
  • 148 Answers
Check where your power and ground is coming from. for best results i would stay away from factory power and ground, i would run the power (+12v NOT the switched 12v) straight to the battery and ground the unit to a known good solid ground. what your hearing might be interference from lack of solid connections. if your running amplifiers make sure the power and ground are properly connected and grounded as well. you can also try ground loop isolators on the amplifiers white and red wires.
Posted on Feb 16, 2009
HUSQVARNA TRACTOR AFTER ADJUSTING DECK HEIGHT ENGINE TURN KEY ENGAGE BRAKE PEDAL ENGINE WILL NOT START UNTIL PEDAL IS MOVED BACK N FORTH CRANKS AT A CERTAIN POSTION ?
sounds like you may have knocked the safety switch out of its position. check to be sure they are in the correct position and are still hooked up to the wire plugs.
Nov 13, 2016 | Husqvarna Garden
GMOS-04 wiring kit for 2005 YUKON DENALI XL
You need to talk to the experts on auto sound issues like this one.
www.crutchfield.com
Jul 05, 2016 | 2005 GMC Yukon Denali
Hi I've purchased a new double din stereo for my vw sharan 02 reg plugged it in and it's permenantly live any ideas
Check colour coding off old unit plug too new unit plug sounds like acc wire is in wrong position for your model. Put stereos together an check loom from actual deck should have a plug on end make sure both same, if stereo has no plug from it an you plug loom into rear of unit then wrong stereo given an you will need service manual to correct wiring positions.
May 05, 2015 | Cars & Trucks
Loud buzz from deck, seems to be coming from RCA cable
It seems that is bad grounding of the gear, check i everything is conected to ground. I can also be the quality of the cable, Bad cables can produce a lot of noise, try using other cables.
Apr 07, 2015 | Technics SL-1210 Turntable
WITSON DOUBLE-DIN DVD GPS NO AUDIO
This sounds like a setting found in the OPTIONS or SETTINGS portion of your MENU. As the "Safe Driving" banner implies, the voice has been muted. I use a TOM-TOM system which has voice adjusting capabilities. Most likely someone found the voice annoying and shut it down or someone did not want you to be distracted by the voice feature.
This is a little thing to fix and if you can not reprogram it, a BMW Dealer may do a Courtesy fix to build a Relationship with you.
I hope my solution is helpful.
Aug 05, 2012 | BMW Cars & Trucks
Hi ive got an 12VCITY MA-7004 double din dvd player unit for my car (vw golf mk4) I can watch dvds but there is no sound atall when i put a dvd in or a cd, It did have sound when i 1st had it wen i
hi, i bought <a href="http://www.12vcity.com/wholesale-car-electronics-car-dvd-2-din-car-dvd/13-car-double-din-dvd-player-buy-car-double-din-dvd-player-ma-dvd7004.html">12VCITY MA-7004</a> on 12VCITY official, i also changed the wire so as to watch car DVD, but everything turn out to be fine.I think maybe you have connect the wrong wire and have bum out the built in amp.
Jan 11, 2012 | Car Audio & Video
2003 hyundai tiburon dual din JVC touch screen deck installation issues
Hello, Chose another powersource for your device. It is possible that you are tied into a circuit breaker that is constantly resettting. Maybe use an MP3 player for the trip and work on it when you get back.
Dec 09, 2011 | 2003 Hyundai Tiburon
I am looking at bluetooth radios for my wife's chevy Venture (2005). I keep seeing Double DIN is this correct?
yes this vehicle has a double din radio. the old standard radios like most aftermarket are single din,double din refers to being double size of this.
Dec 13, 2010 | 2005 Chevrolet Venture
Gvox AT206
Please note that I do not have a GVOX DV806. I have a GVOX AT 206. Its a double din deck with a built in screen on front. I still need some information on this deck please. Any information would be welcome. I think it was made in Japan or China.
Feb 08, 2008 | Gvox DV-806 Car Video Player
Boss AUDIO SYSTEMS BV9455 Car DVD Player Logo
153 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
