Question about Lexmark X1240 All-In-One InkJet Printer
How to install printer ?
I have a Lexmarkx1240 printer and when I try to print it goes to fax. Someone gave me this printer and I unhooked it from another computer and hooked it to mine.Please help me get it to print.
  • Lexmark Master
  • 684 Answers
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Posted on Feb 16, 2009
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
After downloading and install the update, please try the steps given above.
Mar 02, 2015 | HP LaserJet 1018 Printer
My Brogher MFC-7840W is not printing any fax or sending any fax. When someone sends me a fax, it rings and then it goes dead. When I try to send a fax, it scans the document but then goes dead. I don't...
normally the only thing that could block you from sending a fax would be the connection to the phone line. make sure the phone wire is plugged into the line jack (not ext) and going straight to the wal, no splitters or extensions. if it still cannot send after this try another wire or jack
Mar 24, 2010 | Brother MFC 7840W Printer
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer ip is not getting reply
Do you have printer enable kit installed? These copiers come with network interface board installed, but need the print kit to enable printing functionality.
Sep 04, 2009 | Canon Office Equipment & Supplies
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Office Equipment & Supplies
Panasonic DP 180 - will not print faxes
you need to do an all job clear in fax mode. leave me a msg and i will try to help
Oct 04, 2008 | Panasonic Workio DP-190 Multifunction...
sometimes the print heads will become blocked. Take the catridges out and put a piece of toilet paper across the head and see if ink bleeds through. if not try moistening some kitchen paper and gently cleaning the heads.
Nov 13, 2007 | Lexmark X1240 All-In-One InkJet Printer
Can't open the printer driver that I downloaded, on a mac computer
I'm sorry but when you look at specs on this machine from Canon it states that Mac is not supported on the MP360.
Nov 01, 2007 | Office Equipment & Supplies
Not printing at all
This might sound a little obvious, but I've seen it before. But did you peel off the plastic covering from the cartridge before you installed it?
Jul 31, 2007 | Canon MultiPASS C2500 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
148 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
