Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw stops when i give it gas.
Choke it, start it, push in the choke and then it dies when i pull the trigger. then it will only start again by choking as if it were cold. has a new plug and new gas, chain runs free and so on. any ideas? thanks.
  • Anonymous Feb 18, 2009
    my husqvarna 340 chainsaw has a problem.choke it!start it!as soon as i depress the choke and give it some throttle it stalls.Any help would be great!thanks!
  • 360 Answers
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Posted on Feb 16, 2009
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Bought a McCulloch M3414 started okay yesterday wont start today maybe I flooded it, pulled cord so many times
1. set on/off switch to on, 2.prime it first, push the bubble about 6x 3. pull the choke all the way out, 4.pull trigger and string simultaneously 5. push in choke halfway try again, pull choke back out and etc. should start after repeating steps 4 and 5 3x or 4x when it does start, pump the gas at half choke then let it idle untill it stops push in choke all the way and it should start. don't forget to check the safety bar in front of the handle usually works with most gas operated tools
Jan 04, 2013 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Have new 450 and is very difficult to start. Lost or didn't get book. How do I start it and re-start it while still warm??
Start procedure is, push the primer as many times as it takes to 3/4 fill the bulb ( you cannot over prime it ) pull the blue choke lever fully out,place the saw on the ground with your right boot through the back handle, crank the engine until it fires once, do not continue to crank the engine with the choke out ( they will not run on choke, only fire ) push the choke fully home, crank the engine until it starts, blip the throttle trigger to bring the saw to idle, warm engine, pull the choke fully out and push in again without cranking engine, this will engage the part throttle, crank the engine until it starts, blip the throttle to bring the engine to idle.
May 18, 2011 | Husqvarna 450 e-series 18" Chain Saw
Runs first 30+ sec then bogs out/dies when throttle pressed
If still under warranty have it serviced (authorized dealer not Joe's lawn mower). There should not be a fee (paid by Husqvarna). There have been carburetor problems. If you adjust it your warranty will likely be void; Joe's small engine service just as likely to void any warranty. Are you using a fresh 40:1 fuel oil mix. The will not start with choke set is normal. Start procedure in your OM says listen for sputter and disengage choke. Almost all new saws have similar start procedure.
Start Procedure
Cold:
  1. Ignition on/off to on.
  2. Set compression release – optional step even if saw is equipped with a compression release.
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts. (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull).
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Wont start what is spark plug gap whatelse bulb full,new,gas in it,lines hooked
These are bad about flooding with the least amount of trying to. I usually can get mine started by letting it sit for 5-10 min. push the bulb 3-4 times hold the trigger and push the choke on full with 3/4 speed set. Pull 1x. Don't worry usually it won't start on this setting, it really just helps get the choke and carb set. Put choke back 1/2 way and try to start, if so, gas the trigger a couple of times but not holding in down. If it don't start put the choke on full again and try to start without holding the trigger. It should start after this. Take the plug out replace the coil wire onto plug and pull the cord gently to see if you're getting spark at the plug. Holding the coil boot to prevent it giving a small jolt.
Jul 27, 2010 | Homelite Mighty Lite Lawn Trimmer
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starts and then runs wide open.
SOUNDS LIKE THROTTLE NEEDLE STUCK OPEN CHECK THROTTLE LINKAGE STICKING OR RETURN SPRING
May 19, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
598 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
