Question about Lexmark X1240 All-In-One InkJet Printer
How to install printer with no cd-rom?
I have a Lexmarkx1240 printer it doesnot print it only goes to fax mode. I donot have the cd . I got the printer from someone who had it hooked up to another computer and I just hooked it up to my computer. Please help me get it to print.
  • 565 Answers
How can I get my epson sx115 scanner/printer to work and pair it with my laptop with the cd rom instructions ? I put the printer wire in recently and does not print.
Use the setup wizard given in the CD along with the printer.
Check if the printer drivers have been installed in the laptop.
Donot connect the printer before installing the software.
Initially use the CD and follow the instructions on the screen
You will be prompted to connect the Printer after the installation is done.
Connect and then try a test print when instructed.
Jun 02, 2011 | Office Equipment & Supplies
First check if the printer is already installed into your computer.
Start>Control Panel>Printers and Faxes, then check if the printer was installed. e.g. Canon Pixma MG5270
If not please do the following:
1. Check if your printer is connected to the computer via USB, and check if you properly plugged in the power supply.
2. Look for the software or installer of your printer. Insert the CD to the CD-Rom and Install it until the setup completes.
3. After the installation of the printer, click Start>Control Panel>Printers and Faxes, then check if the printer was installed. e.g. Canon Pixma MG5270
4. Then try to print out some document. Just click File>Print and choose your Printer e.g.(Canon Pixma MG5270) then click the O.K. button to print the document.
Mar 22, 2011 | Computers & Internet
My brother 2070W acts like it receives the data, but it never prints
When reconnecting the USB cable to the computer or laptop the cable must
be reconnected to the same USB port it was previously connected to. Otherwise, Windows will install another copy of the printer
driver and the printer will no longer print. Most computers have two or
more USB ports. To prevent this problem from occurring we would
recommend labeling the end of the USB cable to indicate which USB port
the cable must be reconnected to.
To resume printing the printer driver should be removed then
In Windows 2000 open Start, Settings and Printers. In Windows XP open
Printers and Faxes. Double click one of the Brother printer icons to
open the print queue. If print jobs are listed click Printer and Cancel
All Documents. Repeat this process for all copies of the Brother printer
Delete all copies of the Brother printer driver by selecting the printer
and clicking File then Delete.
Once all the copies of the Brother printer driver have been deleted
click File and Server Properties. Click the Drivers tab. Select the
Brother printer from the list and click the Remove button. Click Close.
The printer driver can be reinstalled using the Brother CD-ROM or
downloaded from the Brother Solutions web site. Check the CD-ROM to
verify it lists the operating system installed on your computer. If your
operatingsystem is listed insert the CD-ROM and install the printer driver.Before installing the printer driver disconnect the USB
cable from the back of the printer. Do not reconnect the USB cable to
the printer until the installation prompts you.
If the CD-ROM does not list the operating system installed on your
computer the CD-ROM should not be used to reinstall the printer driver.
The newest version of the printer driver is available for free download
from the web site below.
How to install the downloaded driver:
1. Download and save the Windows 2000/XP driver to your desktop.
2. Once downloading is complete, Double-click the file to open the
WinZip Self-Extractor. In the Unzip To folder section, change the path
to c:ro, click Unzip and click OK. Click Close to close the WinZip
3. Open Printers or Printers and Faxes.
4. Click Add Printer or Add A Printer.
5. Click Next on the first screen. Select Local printer. Remove the
check from Automatically detect and install my Plug and Play printer and
click on Next.
6. Select a USB port and click on Next.
7. Click the Have Disk button and type the directory c:ro.
8. Click on OK.
9. Select the model and click on Next.
10. Select Yes to use the printer was the default printer then click
11. Select Do not share this printer or Share as and click on Next.
12. Click on Yes or No to print a test page.
13. Click on Finish to complete the installation.
Do give my solution the highest rating if it solves your problem. Thank you for using fixya.
Aug 04, 2009 | Brother Office Equipment & Supplies
When i give the command to print , it doesnot
Go to the Control Panel>Printer and Faxes>Double click on "HP Officejet 5610" and check that is any pending jobs or not in queue.
If yes then delete all of them and then give the print command.
If the deleting will not happend then shutdown your pc and on it after 2 min and then try to print.
If this is not helpful then :
1) Check all the cable of printer that it is attached properly or not.
2) Remove the printer driver and restart your machine and than install the fresh copy of your printer driver.
Mar 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Problems installing my printer
From Canon download page download driver for your OS and install it.
Download and follow instructions in user manual too
Feb 22, 2009 | Canon SmartBase MP730 All-In-One InkJet...
How to install printer ?
Just go to Control Panel...........
Printers Folder...........
There u will see a Chk mark on Lexmark Fax X1240........
And u will see another icon which says Lexmark X1200 Series just right click on Lexmark X1200 Series not the Fax and Click on Set As Default Printer...............
After u do this U can go ahead Print............
Good Luck
Feb 16, 2009 | Lexmark X1240 All-In-One InkJet Printer
Touch screen on kyocera 5035 isnt working
Look for a stuck key on the operation panel. Usually is the least used key, a grain of salt will do it!
Jan 27, 2009 | Kyocera Copystar CS-5035 Copier
Lost installation disk for canon pixma iP 1500 inkjet printer
follow the following link to make it worksl;
firstly, go 2 d printer and faxes folder then add a new printer
then it will display some connection wizard 4 u.
where u will choose 4rm other alternative that is manually not 4rm cd rom
there u will find diff. kind of product 4 ur printer where u will choose the model, if u can find the model choose other
finally, print a test page and ur printer brgin to work automatically
Sep 04, 2008 | Office Equipment & Supplies
Goes offline and if on line doesnot print document
Jan 10, 2008 | HP Deskjet D2360 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
102 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
