Question about RCA HD61LPW175 61" Rear Projection HDTV
RCA HD61LPW175 will not turn on
I checked the bulb and it looks good. I get no sound and no picture. The buttons in the front flash five times, stop, then flash five times again.
  • RCA Master
  • 5,138 Answers
Replace the Lamp if you have played it over 5000 hrs.
Posted on Feb 16, 2009
HD50THW263: got a new/refurbished bulb. The picture was dark and would not brighten. A week later the TV would wind up but would not show a picture then the mechanical sounds would stop and the operation...
If you have replaced the Lamp then its a good chance that the Ballast Board also needs to be replaced ,it is what powers the Lamp on.
Encompass Parts Distribution 1-800-638-3328
PTS rebuilt boards 1-800-844-7871
Jul 22, 2011 | RCA HD50THW263 50" HDTV
I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
easyab
May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
NO PICTYURE OR SOUND LIGHGTS ON FRONT COME ON BLINK FIVE TIMES THEN GO OUT
Thats a common problem with the RCA ATC336 Power supply when the capacitors fail on the AC in power board. You can get the repair kit at the following link which will usually repair that symptom.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
May 23, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
I need help with my rca tv
probably bad color wheel. not an easy repair. some of the rca dlp required the light engine be
pulled out to replace color wheel.
Feb 24, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
No picture (fan& bulb do not come on) but there is sound
I have a RCA 52inch D52w136D, the power button blinks three times, but nothing happens no picture or sound
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TOSHIBA 52 INCH PROJECTION TV - 2003 MODEL
Hi olchap
your tv is projection, maby the heat is causing the bulbs to brighten and dim, you should try to keep the room its in fairly cold or try and have the bulbs replaced to ones that are not as strong,
hope that helps a little ^-^
Jul 29, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Black Screan
THe lamp has shatterd inside its housing. remove the broken lamp and replace with a new one that should solve the problem
May 04, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Online guide to RCA M50WH72S Television
i do not know what happened to my RCA model # M50WH72S
i woke up and went to turn it on and the power was already on and the screen is black and no sound. and the television wont turn off with remote or from front of t.v i have to unplug it. same thing once i plug it back in the t.v power button is on and no picture or sound and wont turn off does anyone know if i need to replace a part ? and where i could find it i dont wanna pay a lot to have someone look at it. i checked the bulb and its in good shape. please help.
Oct 19, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD61LPW175 61" Rear Projection HDTV Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
