Question about X2Gen MG19MY 19" LCD Monitor
I installed a new video card in my system. I am not getting any picture on my screen. I contacted dell and it was determend that I might need some assistance from you. can you help
  • 2 more comments
  • bxskate Feb 16, 2009
    have done this twice already to no avail.
    visiontek radeon 256m 2400pdms59pcie v2400dmspcie
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is this connected using the VGA connector or the Digital connector?
    Was the drivers installed before the card was inserted?
    Is there and internal video card on your motherboard that needs to be disabled?
  • Tim Babcock
    What is the make and model of the video card?
  • 3,051 Answers
Hi there ok you can try this first turn off the computer unplug the powercord from the computer , remove the monitor cable then open the case, remove the card and ensure that the slot is free of any debris canned air works good for this now now press the card back into the slot firmly and dont forget to put the screw back in if it has one now find the powersupply cable that hooks into the motherboard and unplug it and wait about 10 seconds now press the power on button on the front for 5 seconds this will clear the system now put the connector back into the motherboard and ensure that all of the cables are firmly into place hook up the monitor cable back up and put the power cord back into the computer and turn on the monitor and turn on the computer and see what happnes ok this should help if not let me know there is still things we can check ok best regards mike
Posted on Feb 16, 2009
  • Michael Thomas
    Michael Thomas Feb 18, 2009
    hey is there any beeps on startup
  • Michael Thomas
    Michael Thomas Aug 06, 2009
    Have you got the problem resolved or is it still there
Dell dimension 4550... no display on screen after a restart, took video card out and put it back in, picture came back until the next restart, now once again no display... what do I do?
sounds like a video card or slot issue. try to turn off the computer, disconnect the power cord, then remove the video card. try to blow dust from the video card slot using compressed air or use a vaccum. after that, press the power button for about 10 seconds to discharge any power left on the system board. reconnect the video card, reconnect the power cord and test. if same issue, try resetting BIOS defaults, try to update the chipset and BIOS. If both fails, try testing the video card on another system. if it is a PCI type of card, try testing it on another PCI slot on your system if available. if the card has same issue on another system, time to get a new one or use the onboard video card temporarily. Also, observe if video only disappears when Windows is already trying to load. if that is the case, either a video driver reinstall or operating system reinstall may also be needed.
Sep 06, 2010 | Dell Dimension 4550 PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
How or where in the BIOS do I switch video source to PCI? Old Dell PowerEdge 600SC. Attempting to install new video board.
Most servers (including the 600SC) were not designed for use with add-in video cards, thus, there is no jumpers or BIOS setting to disable the onboard video.
Mar 13, 2010 | Dell PowerEdge 600SC (Refurbished)...
Fried Video Card
if you "fried" the video card you wouldn't get anything on the screen. Most Likely the wrong driver got installed or you need to check video properties to set video screen size and drivers installed.
Happens when installing updated video drivers.
Note: MS Update has installed incorrect drivers because thay were "NEW" but were incompatible with the video card on my systems before. Had to unistall "NEW" and reinstall "OLD".
Feb 02, 2010 | Dell Inspiron E1705 Notebook
MY DELL DIMENSION E521 WONT BOOT WINDOWS AFTER STARTING UP, I WAS TOLD THAT THE VIDEO CARD COULD BE BAD, WHERE IS THIS LOCATED IN MY PC AND CAN i USE ANY VIDEO CARD TO RPLACE THIS?
Hello, if you were told by an expert tha you need a video card, here what you need:
1: You do not have a slot card type video card in your system( Dimension E521) your system has on board video, which you can not remove from the system but disable it.
2: Your system has PCIe x16 slot that can be used for new video card.
3: Link below will give you a list of PCIe x16 video cards, you can pick and choose according to your needs. Do you need DVI (digital connection, does your monitor has a white port in the back or just the blue one?), or regular VGA (blue port) is enough, do you need HDMI etc...
bottom line is any of those video card will work.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048%201069609641&Description=pci%20express%20video%20card&name=PCI%20Express%20x16&ActiveSearchResult=False
4: I am assuming you have never done this before so before you open up computer and start taking things apart go to the link below and download service manual for Dell Dimension E521 ( I selected the model for you so you don't have to look for it :-) )
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/index.htm
5: In the service manual link there are several Sections like:
Before You Begin
About Your Computer
Technical Overview
Specifications
Advanced Troubleshooting
System Setup
Removing and Installing Parts click on each one and read about it first to familiarize your self with the system.
6: Once you feel confident enough remove the power cable from from computer.
-> open computer cover
-> follow instructions in service manual under
->Removing and Installing Parts
-> Cards
->PCI Express Cards
-> Installing PCI express card.
-> Close computer cover
-> plug monitor cable to new card
-> power on the computer
-> if Picture quality is bad that means card was not properly recoginzed, install drivers from the CD that came with the video card.
I hope this helps, if you get stuck at any step or not clear feel free to post back.
Kind Regards,
Amar Sondhi
Feb 01, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Can't install NVIDIA Go5200 64MB on Dell Inspiron 5100, WinXP Pro SP3 (fresh install) to replace ATI Radeon 7500 32MB. When I start system with new video card, screen stays blank (black, actually)! Card...
No, you shouldn't need to install driver first. I checked the video card, and it should work fine with your system. You need to go into bios and change to vga mode or the other mode( I don't remember for agp)
Sep 28, 2009 | Dell Computers & Internet
SYSTEM LOCKED - VIDEO DRIVER ERROR
Why dont you try to remove your video card and then connect it properly.and then check if you are getting the error.or try to re-install the video drivers.
Mar 04, 2009 | Nvidia Quadro FX 1400 Graphic Card
Dell Dimension 5100 won't start with new FireMV 2400 PCI Express video card
Did you check to make sure the video card is installed in the right spot? Has the onboard video card been disabled in Windows - and when you say it will not boot, do you mean physically no POST. Do you get any error codes? If you can get into the CMOS (Bios) Setup screen - change the primary display adapter from the onboard to AGP, PCI, or PCI-E depending on which card that is. Use this information at your own risk - hope it helps.
Aug 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
DELL DIMENSION 2350
the problem can be from  the video card or from  the monitor.for the monitor go to the officila dell site..there you can  find all the drivers you need..and for the video card instal a new propper driver..
if all this doesnt work..well contact a specialized Dell service..
bye
Feb 03, 2008 | Dell Dimension 2350 PC Desktop
X2Gen MG19MY 19" LCD Monitor Logo
141 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
