Question about Panasonic CS-A12C Air Conditioner
Single Split Air Conditioner > Deluxe Inverter > CS-S12HKQ
I would like the manual for the remote to set the time and understand all functions
bobotfel
  • 236 Answers
SOURCE: Centrex air conditioner
Here are some icon that may help you.
COOL- this icon cool your room.
Dry- this icon control the humidity in your room but limit the coolness in your room (24deg C).
Fan- this icon run for fan only.
Heat- this icon heat your room.
Posted on Mar 12, 2008
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
SOURCE: Westpoint split air conditoner remote contol unit
I want to locate a Eolia West Point A/C remote
Posted on Oct 23, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Getting the batteries out of the remote unit for a
Try sliding the remote cover all the way off
Posted on Nov 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
User manual. Where can I get a copy
Pioneer Mini Split AC - Wholesale Prices, Open to Public‎
Adwww.highseer.com/Pioneer-HVACInformation & Support
Download Manuals, Parts Diagrams
Sales, Technical Brochures & More
Nov 08, 2015 | Pioneer Ductless Mini Split INVERTER Air...
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Where can i get panasonil CS-YS24RYK operating manual ?
http://www.retrevo.com/samples/Panasonic-Air-Conditioner-manuals.html
May 03, 2015 | Panasonic Single Split Wall Mounted Air...
One year old Panasonic Split system only blowing air
The compressor may possibly still be working but has no more freon. Ths may be caused by a leak.
Nov 16, 2013 | Panasonic Single Split Wall Mounted Air...
I have haier split air condition Hsu 18ck03 When power supply off and comes back i manually switch on from remote.i want it auto on
Your air conditioner is not a inverter model(your model is it a low cost model )and doesn-t work automaticlly when the power is off
Aug 01, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Seting remote ac lg
Why water leaks from split type non inverter Air Conditioner?
Mar 24, 2013 | LG LSC121PMA Split System Air Conditioner
Split system not starting up for about 10 mins after turning on
Hi Wendy,
The manual for the unit is at this link. This should answer all your questions. http://panasonic.com.au/products/details.cfm?objectID=4601 then go to the bottom of the page and click on CS/CU-E18_21_24_28HKR Operation Manual
I take the time to answer you questions so please rate me
Thankyou
Mat
Jun 10, 2009 | Panasonic MCM INVERTER
I can't change the fan mode to cool mode.
Go to the manufacturer website and try and find their download page for the manuals or literature. If they don't have a download, you will have to contact them either by phone or email. They should be able to mail or fax you one.
Apr 05, 2009 | Sanyo 24KS72 Split System Air Conditioner
Air con model no CS-1273KR
Okay, the question WAS asked just over six years ago, but I see that it hasn't been answered yet:
To set the time:
1. Open up the "door" in front of the remote.
2. Press the little round button beneath the "UP-DOWN" button.
3. Set the time using the ?P-DOWN" button.
(How I know? I double-checked it with my remote, which is an A75C377).
The manual does not show you how to set the clock; only how to set the time. Manuals are available online - do a Google Search...
Oct 13, 2008 | Panasonic CS-A12C Air Conditioner
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
219 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
