Question about Sony KP-51WS500 51" Rear Projection Television
Projector went out
How much to replace and where do I find one?
  • ladywinn
    ladywinn May 11, 2010
    Replace What?
  • 25 Answers
I assume you mean replace the dlp lamp inside a rear projection television. You didn't give a model or TV brand, so I can't point you to a direct lamp model to buy. Best I can do is say, go to http://www.dlplamps.com and see if they have what you need there.
Posted on Feb 16, 2009
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
Heard a pop sound and projector will not power up
The power supply on the projector went bad...
To replace this will be more then the projector is probably worth.
You can return it to the manufacturer for a quote, but you will need to pay the shipping charges to get the quote from them.
heatman101
May 08, 2011 | InFocus LP 600 Multimedia Projector
Heard a pop and then the bulb went out -- is the fix, bulb replacement normally?
yes. when you replace the lamp, make sure to blow the dust out of the projector with canned air. this will extend the life of the lamp. also reset the lamp timer.
Mar 15, 2010 | InFocus LP500 Multimedia Projector
My lreplacement lamp is working but i can't get a signal from dvd
Make sure the DVD is connected to the Projector and both are powered up.
Select the correct input Source at your projector by going to the menu of the projector.
After a couple of seconds, it should synch up.
Sep 25, 2009 | ViewSonic Projector PJL855 Multimedia...
Light went out
then it may not be the lamp, but make sure you have the right one (sp-lamp-021). also check to see if the colorwheel is moving. turn the projector on and listen for a high-pitched whir. if you don't hear one, the colorwheel needs replacing. and the lamp won't light without the colorwheel spinning.
Jul 17, 2009 | InFocus ScreenPlay 4805 Multimedia...
The color went out on my Toshiba TDP-T45 projector. Watching the projector and heard sound and the color went away. What is wrong?
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Apr 23, 2009 | Toshiba TDP-T45U DLP Projector
Liesegang Piccadilly Pro Projector (DLP) won't go into sleep mode
has it ever stopped, or did it go after the lamp did? if it did, it may be that the thermoresisters inside makes the projector think it's still hot. they need to be replaced.
Dec 16, 2008 | Liesegang Piccadilly Pro DLP Projector
Canon projector Dim & yellow
Yes, thsi can be a problem with the projector bulb and you may need to replace it already..
Hope that helps.........
Oct 03, 2008 | Canon LV-7230 Multimedia Projector
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Apr 09, 2008 | Optoma EzPro 739 Multimedia Projector
Sony KP-51WS500 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
