Question about Baby Lock Esante
Problem with my Babylock embroidery machine
My Babylock Ellegante is bunching up the upper thread under every design I try to sew. It simply ruins the design. The machine is less than 3 years old and the man who serviced it says all these machine do this. I find this hard to believe, since it did not do this when I first purchased it. He said most people who have these machines are disappointed with them.. Please, Please help,
There is a switch on the back of machine, switch to embroidery mode.
Posted on May 17, 2013
I had this problem. You need to be sure that the upper thread is not catching on something. Also, be sure to take out the bobbin case and brush out the area in and around that area throughougly, after every use. Lastly, use a good brand of thread.
Posted on Jan 24, 2010
I think you may have forgotten to put on the Q presser foot.
Posted on Feb 28, 2009
What is wrong when the underside of embroidery has bunched thread
Hello
The bunched-up thread on the underside is the needle thread. Check that the upper thread is threaded correctly, passing through all the required thread guides and that the thread is securely lodged in the tension assembly ... there should be reasonable tension when upper thread being pulled by hand.
Also check that:
- there are no 'dust bunnies' or a piece of thread hiding in the tension assembly, and that
- the needle is inserted correctly and that it is a system 130/705H Embroidery needle.
Happy Stitching
Sewingirl/
Apr 23, 2017 | Sewing Machines
Upper thread loops
Hi Nisha, The link below is a YouTube video showing how to thread your sewing machine, Also there's videos down the right side of the link that may help as well.......... CHEERS..
Sewing Machine Tension Tips
May 07, 2016 | Sewing Machines
Having trouble with tension on my Husqvarna Viking E 20
Be sure to RAISE the presser foot BEFORE threading the upper thread. (Remove the upper thread and rethread from the beginning.) Upper thread malfunctions commonly occur if it is not threaded correctly or the thread is not seated in the tension disk properly.
Install a brand new needle if you haven't already done so.
If it continues, this information about bird nesting could be helpful:
Sewing Machine Thread Bunching Up Here Why
Why Do Get Bunched Up Thread Under My Fabric
8 Tips to Fix Birdnesting in Embroidery
Why Is the Thread Getting Tangled Up Under My Material When Use My Sewing...
Jan 22, 2016 | Husqvarna Sewing Machines
WHAT DO I DO TO GET MY BABY LOCK ELLURE ESL TO PICK UP THE BOBBIN THREAD?
You have your bobbin inserted into the machine spinning in the wrong direction. take the bobbin out and flip it over and wind around needle plate guide and cut. Look at the little pictogram on the plastic part of the machines throat plate. It shows which direction the thread should spin off the spool when you drop the top loading bobbin into the bobbin case.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Aug 30, 2014 | Baby Lock Ellure
Babylock ellegante 2
Threads bits/dust has accumulated at top thread sensor or the sensor need to be replaced
Oct 30, 2013 | Baby Lock Ellure
Babylock sewing machine, upper thread is bunching
the tension is wronge has the lower bobbin case been unwound and refilled)(check that this is threaded right as well)
Sep 05, 2009 | Sewing Machines
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Baby lock Ellegante 2 embroidery machine
try and look here
http://www.babylock.com/embroidery/ellegante/
there is a help section
Jan 11, 2009 | Baby Lock Ellure
Embroidery sewing machine stopped working
I am not sure what you mean: motor runs but nothing else moves?
Have you have turned the machine off and tried again? Like computers, sometimes they need rebooted.
More information is needed to evaluate further.
Dec 29, 2008 | Husqvarna Designer I
Designer 1
after 8 years of sitting, the machine needs to go to the shop so that areas that are inaccessabe to the sewer can be cleaned and serviced by the tech. also check the upper threading of the machine. the tension is changed if threaded incorrectly. bunching under the material is caused by several different reasons. I would first have the machine cleaned and serviced by the tech, and let them know it has been 8 years since use. we all begin walking by taking one step at a time.
del
Apr 16, 2007 | Husqvarna Designer I
Sewing Machines Logo
593 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
