Question about Maytag Kitchen Ranges
LP conversion of oven burner and adjustment of burners
We have recently converted a Maytag Gas Range from Nat'l Gas to LP. The user guide have three models listed MGS5770/MGR5870 and MGS5870. We successfully converted the pressure regulator and each of the burner orifice hoods under the sealed burners (screwed orifice hoods completely down against the pins per the instruction manual). Did the same thing for the upper and lower oven burners. All air shutters are open fully. Questions
1. The top burners work well except that it takes a really long time (15 min+) for a moderate size pot of water to boil. Should we back the orifice hood away from the pin a turn or two?
2. The bottom oven burner flame is much too big - lots of yellow flame and a black carbon deposit coming from the top vent. The install manual says to replace the orifice hood with a 1.25 mm orifice hood. The manual shows a hood with female threads that fits over the orifice base. The actual oven orifice is male threaded - it fits down into the orifice base. So - do we need to purchase a 1.25 mm male threaded orifice hood and, if yes, how do we disassemble the oven burner in order to make the replacement. A part # and source would be greatly appreciated.
FYI - the reason we don't know the exact model no. is that the local Maytag plant donated some of these ranges (after the Whirlpool buyout) to the local Habitat for Humanity store that we like to patronize. Maytag removed the serial no./model no. plate from the bottom drawer. We guess they didn't want to provide warranty support on stoves that they donated. Oh well, bet they took the full retail price tax deduction anyway - sigh! The user guide have three models listed MGS5770, MGR5870 and MGS5870
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Posted on Feb 21, 2009
SOURCE: LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
Posted on Nov 27, 2009
TheMobilian
  • 8220 Answers
SOURCE: I just bought a newer
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
Posted on Jan 14, 2010
TheMobilian
  • 8220 Answers
SOURCE: Having just converted my Vulcan
The oven safety valve has to be cranked down for propane.themobilian_815.jpg
Get a good fitting wrench and tighten this spud down and open the air shutter on the burner.
This video shows how to tackle a crank down and flip type LP conversion whilst yours might be a bit more fancy it still must be adjusted like any other stove:
Posted on Jan 10, 2011
Why does the oven burner seem to be getting too much gas?
Possible problem with the gas regulator allowing too much gas through the system. On LP systems the regulator should be on the storage tank. The regulator on the range usually has a changeable cap and plunger. One direction is for LP and the other direction is NAT gas. In the LP position, the plunger actually holds the range regulator wide open letting the one on the storage tank do the job.
May 02, 2015 | Kitchen Ranges
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
Having just converted my Vulcan Endurance G36L Range from Nat. Gas to LPG Using the following parts recommended by Vulcan : New 1/2 psi pressure regulator, 6 size 51 hood type top burner orifices,1 size...
Jan 10, 2011 | Vulcan G36L Gas Range
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Swithed to LP
did you change the ovens burner orfice?if not theres your problem.
Dec 25, 2007 | Maytag MGR4451ADS Stainless Steel Gas...
Kitchen Ranges Logo
540 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
