Question about HP OfficeJet 4215 All-In-One InkJet Printer
Cannot get print operation stays on answering machine.
I stopped a print operation of an email half way through by pushing the cancel button. The printing stopped and printer was turned off. After turning on again it started printing old list from stop point. Again pressed cancel and now have answering maching on screen and cannot get back to doing any printing operations. Have shut off and unplugged but still have answering machine set up. Tried to do a copy operation and worked ok, but then went back to answering maching and will not accept a command to print from the computer. Sure would appreciate any help you can give me.
  • himanshi_20 May 11, 2010
    hey just post question to me agian and follow a link trust me ill solve all your problemss for sure!!!!!
    Problem Solver:
  • 6 Answers
Turn off your printer. then you chose start option from your windows. and click printer and fax option from above of hlep and support switch. and you can chose that printer in which you faced problem. and open that printer option. then you will see pending list of your printer. on that list you select all and do right click on that list and click cancel option.after cancellation of all the pending document. you turn on your printer. right now you can print as per wish.
regard
priyabrata (Be in IT)
Posted on Feb 16, 2009
Is there another way to stop unwanted copies from being printed if the reset/stop button does not work?
If printing from your computer...yes. Go to the cancel print function on your computer and cancel the print. That will stop more copies being printed once you have hit cancel.
Otherwise you would need to switch the power off to the machine and remove any paper. Then turn it on again and play with the controls until you can clear the print memory back to zero.
Jan 11, 2016 | Office Equipment & Supplies
What does the stop button do? I'm out of state and a relative asked me if I knew what the "stop" button does on her presto printer. Our other relative who lives closer isn't available for a few days, so...
Main purpose of stop buttons is to stop the job immediately. If you enter wrong no of prints or copies you have to stop it in flash.This button will do it some times you have to press it more than two times.
Aug 24, 2013 | Activeforever HP Presto Printing Mailbox...
Just changed the toner on my Brother HQ 2000 laser printer and now it won't stop printing old documents that were in the memory, don't need them, so can someone tell me how to cancel it? I've pushed the...
Uninstall the machine. Reinstall the drivers for the machine and your problem should be solved....Remember to turn the power off on your printer and remove the USB or network cords. This should fix it!
Oct 19, 2010 | Brother MFC-7820N Printer
Cancel printing is on and will not turn off after canceling when pushing the stop/exit button. i cannot print anything else. when i turn it off and unplug it then plug it back in for 1 min and turn it back...
You did not list your model but if it is an MFC series then try turning off the machine and then hold down the clear/stop button while turning the power back on. Continue holding the button for a few seconds. This procedure will clear whatever may be stuck in memory. This works on most Brother models but may not work on yours.
Good Luck and Thank You for using Fixya.
Aug 12, 2010 | Brother Office Equipment & Supplies
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
Cancelled a job and it stays in queue
Cancel all the documents in the print queue, (just do it whether they are actually deleted or not), press "cancel" on button the printer and restart your system and also the printer. If possible, please leave the printer switched off for few minutes and don't forget to use the "Power" button to turn if off or on. This will help your printer to restart new print job, all the jobs on the print queue will be deleted/cleared. Good luck, Thanks for using FixYa.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Manual page 6 - top item - A event LED - constantly blinking
it will flash if you have a missed call, look at the missed calls log and it will stop. (press the top half of round button that looks like a little paper scroll)
Feb 24, 2009 | Philips CD4452S/05 Digital Telephone and...
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Cancel incoming fax's
take the paper out of the tray, unplug the machine. while holding down the stop/exit button, plug it back in. good luck!
Apr 29, 2008 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
HP OfficeJet 4215 All-In-One InkJet Printer Logo
94 people viewed this question
Seeker5211
Seeker5211
